this is the main sketch which i hope to clean up and integrate the receive side into .
it includes a water change element
a heater control
timers for all the usual stuff
led indicators for pretty much everything
and i will be trying to add a tft screen later on .
i am the first to admit this is a mess , it is my first attempt and im trying to learn as much as i can .
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 rtc;
// Data wire is plugged into pin 50 on the Arduino
#define ONE_WIRE_BUS 50
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
//12v Relay Unit
const int drainPin = 22; //12v relay module 1 pin 1
const int fillerPin = 24; //12v relay module 1 pin 2
const int moonlightPin = 26; //12v relay module 1 pin 3
const int coPin = 28; //12v relay module 1 pin 4
//240v Relay Unit
const int filterPin = 23; // relay module 2 pin 1
const int heaterPin = 25; //relay module 2 pin 2
const int daylightPin = 27; // relay module 2 pin 3
const int airpumpPin = 29; // relay module 2 pin 4
//Indicator Control Unit
const int buzzerPin = 31;
const int heatledPin = 32;
const int filterledPin = 34;
const int drainledPin = 36;
const int fillledPin = 38;
const int dayledPin = 40;
const int nightledPin = 33;
const int airledPin = 35;
const int coledPin = 37;
const int fullPin = 39;
const int lowPin = 41;
//Inputs
const int startPin = 44;
const int lowfloPin = 46;
const int highfloPin = 48;
const int dayonPin = 51;
const int dayoffPin = 53;
//52 temp
int startState = 0;
int overideState = 0;
int lowfloState = 0;
int highfloState = 0;
int dayonState = 0;
int dayoffState = 0;
// start serial port
Serial.println("Dallas Temperature IC Control Library Demo");
// Start up the library
sensors.begin();
Wire.begin();
rtc.begin();
if (! rtc.isrunning())
Serial.println("RTC is NOT running!");
pinMode(heaterPin, OUTPUT);
pinMode(filterPin, OUTPUT);
pinMode(drainPin, OUTPUT);
pinMode(fillerPin, OUTPUT);
pinMode(daylightPin, OUTPUT);
pinMode(moonlightPin, OUTPUT);
pinMode(airpumpPin, OUTPUT);
pinMode(coPin, OUTPUT);
pinMode(buzzerPin, OUTPUT);
pinMode(heatledPin, OUTPUT);
pinMode(filterledPin, OUTPUT);
pinMode(drainledPin, OUTPUT);
pinMode(fillledPin, OUTPUT);
pinMode(dayledPin, OUTPUT);
pinMode(nightledPin, OUTPUT);
pinMode(airledPin, OUTPUT);
pinMode(coledPin, OUTPUT);
pinMode(fullPin, OUTPUT);
pinMode(lowPin, OUTPUT);
pinMode(startPin, INPUT_PULLUP);
pinMode(lowfloPin, INPUT_PULLUP);
pinMode(highfloPin, INPUT_PULLUP);
digitalWrite(dayonPin, INPUT_PULLUP);
digitalWrite(dayoffPin, INPUT_PULLUP);
digitalWrite(drainPin, HIGH);
digitalWrite(fillerPin, HIGH);
digitalWrite(heaterPin, HIGH);
digitalWrite(filterPin, HIGH);
startState = digitalRead(startPin);
lowfloState = digitalRead(lowfloPin);
highfloState = digitalRead(highfloPin);
if (startState == LOW){// Press a Start Button to start the cycle
digitalWrite(drainPin, LOW); //which operates the drain pump and valve
digitalWrite(drainledPin, HIGH);
Serial.print("Starting Water Change");}
else{
heatfiltcont();
tempalert();
timersettings();}
if (lowfloState == LOW){ // when the water level drops the float switch closes
digitalWrite(drainPin, HIGH); //shutting off the drain
digitalWrite(drainledPin, LOW);
digitalWrite(fillerPin, LOW); // and opening the filler solenoid
digitalWrite(fillledPin, HIGH);
Serial.print("Water Low - Filling");}
if (highfloState == HIGH){ // when the water level is restored
digitalWrite(fillerPin, HIGH); // the filler is shut off .
digitalWrite(fillledPin, LOW);
Serial.print("Full");
digitalWrite(fullPin, HIGH);
}else{
digitalWrite(fullPin, LOW);
digitalWrite(lowPin, HIGH);
}else{
digitalWrite(lowPin, LOW);
void heatfiltcont() { //Switches the Heater and Filter off when the water level drops , and back on when the level is sufficient
if (highfloState == LOW) { //if the aquarium is not full the float switch closes
digitalWrite(heaterPin, HIGH); // the heater shuts off
digitalWrite(filterPin, HIGH); // the filter shuts off
digitalWrite(heatledPin,LOW);
digitalWrite(filterledPin, LOW);
Serial.print("Heater and Filter Off");
}else{
digitalWrite(filterPin, LOW);
digitalWrite(filterledPin, HIGH);
void tempalert() { //Temperature sensor heater off if temp above 27 and on if below 25 unless high float switch is closed and buzzer if below 19 and high float is open
Serial.print("Requesting temperatures...");
sensors.requestTemperatures(); // Send the command to get temperature readings
Serial.println("DONE");
Serial.print("Temperature is: ");
Serial.print(sensors.getTempCByIndex(0)); // Why "byIndex"?
// You can have more than one DS18B20 on the same bus.
// 0 refers to the first IC on the wire
delay(10);
if(sensors.getTempCByIndex(0)>= 27){
digitalWrite(heaterPin, HIGH);//turns off=HIGH
digitalWrite(heatledPin, LOW);
Serial.print("Too Hot , Heater Off");
if((sensors.getTempCByIndex(0)<= 23) && (highfloState == HIGH)){
digitalWrite(heaterPin, LOW);//turns on=LOW
digitalWrite(heatledPin, HIGH);
Serial.print("Too Cold , Heater On");
if((sensors.getTempCByIndex(0)<= 19) && (highfloState == HIGH)){
digitalWrite(buzzerPin, HIGH);
Serial.print("WARNING!!! Temperature Very Low");
void timersettings() { //goal 3 timers(); Set timers for day/night lights and air/co2 with daylight override switch
DateTime now = rtc.now();
dayonState = digitalRead(dayonPin);
dayoffState = digitalRead(dayoffPin);
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(" (");
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
delay(10);
//Daylights daylightPin dayledPin
if (now.hour() == 9 & now.minute() == 0 & now.second() == 0)
digitalWrite(daylightPin, LOW);
digitalWrite(dayledPin, HIGH);
else if (now.hour() == 18 & now.minute() == 0 & now.second() == 0)
digitalWrite(daylightPin, HIGH);
digitalWrite(dayledPin, LOW);
if (dayonState == LOW)
if (dayoffState == LOW)
//Nightlights moonlightPin nightledPin
if (now.hour() == 7 & now.minute() == 30 & now.second() == 0)
digitalWrite(moonlightPin, LOW);
digitalWrite(nightledPin, HIGH);
digitalWrite(moonlightPin, HIGH);
digitalWrite(nightledPin, LOW);
if (now.hour() == 23 & now.minute() == 0 & now.second() == 0)
//Airpump airpumpPin airledPin
if (now.hour() == 19 & now.minute() == 0 & now.second() == 0)
digitalWrite(airpumpPin, LOW);
digitalWrite(airledPin, HIGH);
if (now.hour() == 22 & now.minute() == 0 & now.second() == 0)
digitalWrite(airpumpPin, HIGH);
digitalWrite(airledPin, LOW);
//co2solenoid coPin coledPin
if (now.hour() == 7 & now.minute() == 0 & now.second() == 0)
digitalWrite(coPin, LOW);
digitalWrite(coledPin, HIGH);
if (now.hour() == 17 & now.minute() == 0 & now.second() == 0)
digitalWrite(coPin, HIGH);
digitalWrite(coledPin, LOW);
