Sending tone from Arduino to Iphone 100m
Hi
What you will suggest to use for sending 1kHZ tone to Iphone ?
ups or Fedex maybe ?
:slight_smile:
joke aside, you need to provide way more information about the requirements / expectations
The sensor turns on the buzzer and I want to hear it on the iPhone, I use Bluetooth , but the range is too small
which sensor ? which buzzer ? what do you do with BT ?...
do yourself a favour and please read How to get the best out of this forum and post accordingly (including code tags when you post code and necessary documentation for your ask).
A 1KHZ tone is an ANALOG signal, NOT a digital signal that your iphone could process.
https://content.instructables.com/ORIG/F9T/ML84/JFMTCCKW/F9TML84JFMTCCKW.png?auto=webp&fit=bounds&frame=1&width=1024
I want to hear that sound on Iphone
I give up...
If you just want to hear a tone on an Iphone or any phone there are tone generator apps for that. Next an Arduino Uno as pictured is not sending anything anywhere less wired. Next if I wanted to send a tone over a short distance within a WiFi network I would look at using an ESP or Arduino Uno REV 2 (UNO WiFi). Distance needs defined. No mention of tone duration?
You need to describe in detail exactly what you want to do.
Ron
Use the force, Luke
There is nothing in Arduino world that can send a tone signal 100 meters to an iPhone.
SMS is possible, via the cellular networks or internet connections.
Look up ESP32.
Google:
esp32 to iphone wifi
ESP32 using Wifi.
ESP32 as a web server to iPhone, may give you better range.
Tom... :smiley: :+1: :coffee: :australia:
If you want to pickup a small noise 100m away with the microphone of your phone that is tuned to capture close by sound (voice or shooting video) and cancel some noise then forget it. It’s not going to happen.
Buy a super expensive directional microphone with ability to filter frequencies….
Alternatively build a better system that does not only activate a buzzer when some condition is met but add a suitable radio element (IP over 3G, 4G, WiFi or SMS or Lora or HC12 and all the likes) or a long amplified wire to your project and send a message that will be received where you want to be notified.
your lack of willingness to provide context and specifications won’t get you far here. You really need to up your game if you are serious about YOUR project. If not you are wasting the time of the helpers here.
