sending unix date to lcd
Any suggestions?
Now i have this but it sends it out as hex and after it has been displayed lcd shows some number starting with a minus (-)
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
long txt = 0;
  lcd.begin(16, 2);
lcd.setCursor(0, 0);
  lcd.print("time");
lcd.clear();
  txt = Serial.read();
lcd.print(txt);
delay(100);
The time should state until it changes or is send again via serial.
Why are you storing a byte in a long variable? Why are you not checking that there is data to read before reading it?
delay(100);
If you are not going to do anything, why not not do it right away? This delay call is absolutely useless.
I want it to be text? I have no clue how to do this
If there is no delay the lcd will flicker
The LCD won't flicker if you don't write to it, unless you get serial data.
Is that a question or a statement? Perhaps you should start with defining what is sending data to the Arduino, via the serial port, and HOW.
