Sending value to VB 2012 from arduino uno via ethernet shield
Hi all,
I want to send value from arduino to VB2012 and then display the value on Label or Textbox on VB2012 but i don't know how.
These are the codes that i use for VB2012
Imports System.Net.Sockets
Imports System.Text
Public Class Form1
    Dim tcpClient As New System.Net.Sockets.TcpClient()
    Dim networkStream As Net.Sockets.NetworkStream
    Dim KeyPressed As Integer
    Private Function Arduino_Connect(ByVal IP As String, ByVal Port As Integer) As Boolean
        tcpClient.Connect(IP, Port)
        networkStream = tcpClient.GetStream()
        If Not networkStream.CanWrite Or Not networkStream.CanRead Then
            tcpClient.Close()
            networkStream = Nothing
            Return False
        End If
        Return True
    End Function
    Private Sub Arduino_Write(ByVal Output As String)
        If Not IsNothing(networkStream) Then
            Dim sendBytes As [Byte]() = Encoding.ASCII.GetBytes(Output)
            Dim endByte As [Byte]() = {&HFE}
            networkStream.Write(sendBytes, 0, sendBytes.Length)
            networkStream.Write(endByte, 0, 1)
        Else
            MsgBox("ERROR")
        End If
    End Sub
    Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
        Arduino_Connect("192.168.1.100", 80)
        'Arduino_Read()
        'Arduino_Write("F")
        'STATUS1.Text = "Mati !!!"
    End Sub
    Private Sub Arduino_Disconnect()
            tcpClient.Close()
        End If
    End Sub
    Private Sub btOn_Click(sender As Object, e As EventArgs) Handles btOn.Click
        STATUS1.Text = "Nyala !!!"
        Arduino_Write("O")
    End Sub
    Private Sub btOff_Click(sender As Object, e As EventArgs) Handles btOff.Click
        Arduino_Write("F")
    End Sub
    Private Sub Keluar_Click(sender As Object, e As EventArgs) Handles Keluar.Click
        Me.Close()
        Arduino_Write("F")
    End Sub
End Class
And these are the codes for arduino
#include <SPI.h>
#include <Ethernet.h>
// Wired configuration parameters
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0xD1, 0x4B };
unsigned char local_ip[] = {192,168,1,100};	// IP address of WiShield
unsigned char gateway_ip[] = {192,168,1,1};	// router or gateway IP address
unsigned char subnet_mask[] = {255,255,255,0};	// subnet mask for the local network
EthernetServer server(80);
//char buffer[20];
String buffer = "";
  pinMode(8,OUTPUT);
  Ethernet.begin(mac, local_ip);
  if (client)
    boolean currentLineIsBlank = true;
    while (client.connected())
      if (client.available())
        char c = client.read();
        Serial.print(c);
        buffer+=c;
        int val;
        if (c == 'O')
          digitalWrite(8,HIGH);
        else if (c == 'F')
          digitalWrite(8,LOW);
With those code i've been able to write string value from VB2012 to arduino, so can anyone help me / tell me how to send / write a value (string or int) from arduino to VB2012 and display the sent value on Label or Textbox. Thanks
Where does the Arduino code get data that it sends to the serial port? It gets it from the client object that the VB app is on the other end of. How do you suppose that the Arduino should send data back to the VB app? If you guessed "using the client object" you are right. If you guessed any other method, wrong.
PaulS:
so what should i do? make the VB as server and arduino as client?
this is really new for me and i'm still learning this, so pardon my weird questions..
Use client.print() and/or client.println() to send data to the server.
