Sending values from a function to a switch statement outside of the function
Hello everyone,
I'm having a problem with my code where i try to do something like this:
switch (numh)
    case 0:
      //set shift register to 01010101
    case 1:
      //set shift register to 10101010
    case 2:
       //set shift register to 11001100
//Something completely different
void DisplaySetHour(int numh, int i, int p)//time display function
  if (p == 2) //exit to main menu
    menu = 0;
    menu2 == 0;
  DateTime now = RTC.now(); //GETTING THE CURRENT HOUR VALUE
  if (i == 1)
    if (hourupg == 23)
      hourupg = 0;
      dayupg++;
      hourupg = hourupg + 1;
  if (i == 2)
    if (hourupg == 0)
      hourupg = 23;
      dayupg--;
      hourupg = hourupg - 1;
  Serial.print("Set Hours:");
  Serial.println(hourupg, DEC);
  numh = hourupg;//WRITING THE HOUR VALUE TO THE DISPLAY - DOESN'T WORK
  shifter.write();//UPDATING THE DISPLAY - DOESN'T WORK
The problem is that i would expect the code to send the numh value to the switch function where it gets "encoded"and displayed on the display. However, when I upload the code the number doesn't get displayed.
The end goal of this is to get a live readout on a nixie display as you adjust the values.
My full code is attached if you'd want to take a look and give me some advice.
Thank you in advance.
Nixie_Clock.ino (59.3 KB)
Welcome,
You have to call the function in which there is the switch
void setShiftRegister( uint8_t num )
    switch (num)
   setShiftRegister( numh );
I just tried it.
Works great now.
Thank you for this advice.
Here, have some karma.
