Unfortunately, sprintf on the Arduino doesn't support the %f format specifier. So, you need to approach the problem slightly differently. Separate the value to be sent into its integral and fractional parts:
int tempC1 = (int)tempC;
int tempC2 = (int)(tempC - tempC1) * 100; // For two decimal points
char msg[24];
sprintf(msg, "%i.%i", tempC1,tempC2);
vw_send((uint8_t *)msg, strlen(msg));
Thanks PaulS, that works.
I never would have figured that out myself.
However one more thing, the resulting tempC on the receiver prints
out as xx.0 it seems to truncate the 2 decimal points to just one and
it's always .0 never the actual tempC, which would be xx.xx,(20.59).
I guess the value of tempC2 will always be 0, due to "
I can live with it, it's not a big deal, but for extra 'wow' factor I would like to have print out the actual temp, xx.xx.
Is this possible?
You might need an extra set of parentheses in there (or two), and to change 100 to 100.0, but, yes, tempC2 can be made to equal 59 when tempC is 20.59.
I tried lcd.print(buf), but I got this error:
error "call of overloaded 'print(uint8_t[30])' is ambiguous"
Here is my code;
#include <VirtualWire.h> //
#include <LiquidCrystal.h>
LiquidCrystal lcd(7, 8, 9, 10, 11, 12); //set digital pins
#undef int
#undef abs
#undef double
#undef float
#undef round
lcd.begin(16, 2); //set colums and rows of LCD
// Initialise the IO and ISR
vw_set_ptt_inverted(true); // Required for RX Link Module
vw_setup(1200); // Bits per sec
vw_set_rx_pin(3); // We will be receiving on pin 3 () ie the RX pin from the module connects to this pin.
vw_rx_start(); // Start the receiver
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) // check to see if anything has been received
int i;
// Message with a good checksum received.
for (i = 0; i < buflen; i++)
Serial.print(buf[i]); // the received data is stored in buffer
Serial.println("");
lcd.clear(); //clear screen
lcd.setCursor (0, 0); //set cursor to top row
lcd.print(buf);
Hi.
I'm triying send a float value also. I see the next code:
int tempC1 = (int)temperatura;
int tempC2 = (int)((temperatura - tempC1) * 100); // For two decimal points
char msg[24];
vw_wait_tx(); // Wait until the whole message is gone
The maximum value that can be stored in an int is +32767. The minimum is -32768. The minimum value takes 6 characters to represent. 6 * 2 is 12, plus one for the . and one for the NULL makes 14. So, the msg array could be as small as 14 characters and still hold everything that sprintf could possibly write into it. In reality, it could be much smaller, since the Arduino can't function at temperature near -10,000 degrees on any scale.
But, it's better to have an array that is too large than one that is too small.
