Sending variable to SQL
I have a Mega with a DS18B20 sensor attached, which I've had set up as a webserver, so I can see the temperature. I'm trying to send the temperature to an SQL server, and while the serial panel says it's connected, there's no update to the database, and I can't see if I'm actually posting the variable.
I'm fine with the PHP, and I've checked the SQL server, posting to it using: http://192.168.0.254/insert_temp.php?temperature=23.19
// OneWire DS18S20, DS18B20, DS1822 Temperature Example
// http://www.pjrc.com/teensy/td_libs_OneWire.html
// The DallasTemperature library can do all this work for you!
// http://milesburton.com/Dallas_Temperature_Control_Library
#include <OneWire.h>
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xAB, 0x11, 0xCD, 0x22, 0xEF, 0x33    // Enter your ethernet MAC address. You will find it behind your arduino board.
IPAddress ip(192, 168, 0, 1);        // Set your IP address for Arduino Board
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
EthernetClient client;
OneWire  ds(2);  // on pin 10 (a 4.7K resistor is necessary)
void setup(void) {
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
void loop(void) {
  byte i;
  byte present = 0;
  byte type_s;
  byte data[12];
  byte addr[8];
  float celsius, fahrenheit;
  if ( !ds.search(addr)) {
    Serial.println("No more addresses.");
    ds.reset_search();
    delay(250);
    return;
  Serial.print("ROM =");
  for( i = 0; i < 8; i++) {
    Serial.write(' ');
    Serial.print(addr[i], HEX);
  if (OneWire::crc8(addr, 7) != addr[7]) {
      Serial.println("CRC is not valid!");
      return;
  // the first ROM byte indicates which chip
  switch (addr[0]) {
    case 0x10:
      Serial.println("  Chip = DS18S20");  // or old DS1820
      type_s = 1;
    case 0x28:
      Serial.println("  Chip = DS18B20");
      type_s = 0;
    case 0x22:
      Serial.println("  Chip = DS1822");
      type_s = 0;
    default:
      Serial.println("Device is not a DS18x20 family device.");
      return;
  ds.reset();
  ds.select(addr);
  ds.write(0x44);        // start conversion, use ds.write(0x44,1) with parasite power on at the end
  delay(1000);     // maybe 750ms is enough, maybe not
  // we might do a ds.depower() here, but the reset will take care of it.
  present = ds.reset();
  ds.select(addr);
  ds.write(0xBE);         // Read Scratchpad
  Serial.print("  Data = ");
  Serial.print(present, HEX);
  Serial.print(" ");
  for ( i = 0; i < 9; i++) {           // we need 9 bytes
    data[i] = ds.read();
    Serial.print(data[i], HEX);
    Serial.print(" ");
  Serial.print(" CRC=");
  Serial.print(OneWire::crc8(data, 8), HEX);
  // Convert the data to actual temperature
  // because the result is a 16 bit signed integer, it should
  // be stored to an "int16_t" type, which is always 16 bits
  // even when compiled on a 32 bit processor.
  int16_t raw = (data[1] << 8) | data[0];
  if (type_s) {
    raw = raw << 3; // 9 bit resolution default
    if (data[7] == 0x10) {
      // "count remain" gives full 12 bit resolution
      raw = (raw & 0xFFF0) + 12 - data[6];
    byte cfg = (data[4] & 0x60);
    // at lower res, the low bits are undefined, so let's zero them
    if (cfg == 0x00) raw = raw & ~7;  // 9 bit resolution, 93.75 ms
    else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
    else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
    //// default is 12 bit resolution, 750 ms conversion time
  celsius = (float)raw / 16.0;
  fahrenheit = celsius * 1.8 + 32.0;
  Serial.print("  Temperature = ");
  Serial.print(celsius);
  Serial.print(" Celsius, ");
  Serial.print(fahrenheit);
  Serial.println(" Fahrenheit");
if (client.connect("192.168.0.254", 80))
            Serial.println("connected");
            client.print("POST /insert_temp.php?");
            client.print("temperature=");
            client.println(celsius);
            client.println("  HTTP/1.1");
            client.stop();
        else {
             // If Arduino can't connect to the server (your computer or web page)
            Serial.println("--> connection failed\n");
   // listen for incoming clients
  if (client) {
 //   Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
 //       Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connection: close");  // the connection will be closed after completion of the response
          client.println("Refresh: 5");  // refresh the page automatically every 5 sec
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          client.println("<head><meta name='robots' content='index, follow'/><meta name='keywords' content='Arduino'/>  <meta name='description' content='Arduino'/>  <meta http-equiv='refresh' content='300' ><title>Arduinot</title></head>");
          client.print("<p style='text-align: center;'>&nbsp;</p>");
          client.print("<p style='text-align: center;'><span style='font-size: x-large;'><strong>Welcome To My Home</strong></span></p>");
          client.print("<p style='text-align: center;'><span style='color: #0000ff;'><strong style='font-size: large;'>Room Temperature = ");
          client.print("</strong></span><h style='text-align: center;'><span style='color: #0000ff;'><strong style='font-size: large;'><sup>o</sup>C</strong></span></h></p>");
          client.print("<p style='text-align: center;'>&nbsp;");
          // Date and Time script
          client.print("<script language='javascript'>");
          client.println();
          client.print("<!--");
          client.println();
          client.print("var today = new Date()");
          client.println();
          client.print("document.write(today); //--> </script>");
          client.print("</p>");
          client.println("</html>");
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
   // Serial.println("client disconnected");
Thanks
Try GET instead of POST.
So simple! Thanks worked like a charm.
