sending wifiscan data to labview
hello my name is dodi, i am from indonesia, i am working on my final project in the last semester, i want to move nodeMCU data to labview,
  • nodeMCU has uploaded the wifiscan program to the arduino IDE
    (this program is available when we install the nodeMCU library on the arduino IDE)
  • nodeMCU is connected using USB Type B to the laptop
    then how do i move wifiscan data to labview ?,
    please give me suggestions, references, sample programs, etc. to achieve my goals.
    thank you
thi is my wifiscan code using nodeMCU
    This sketch demonstrates how to scan WiFi networks.
    The API is almost the same as with the WiFi Shield library,
    the most obvious difference being the different file you need to include:
#include <ESP8266WiFi.h>
  Serial.println(F("\nESP8266 WiFi scan example"));
  // Set WiFi to station mode
  WiFi.mode(WIFI_STA);
  // Disconnect from an AP if it was previously connected
  WiFi.disconnect();
  delay(100);
  String ssid;
  int32_t rssi;
  uint8_t encryptionType;
  uint8_t* bssid;
  int32_t channel;
  bool hidden;
  int scanResult;
  Serial.println(F("Starting WiFi scan..."));
  scanResult = WiFi.scanNetworks(/*async=*/false, /*hidden=*/true);
  if (scanResult == 0) {
    Serial.println(F("No networks found"));
  } else if (scanResult > 0) {
    Serial.printf(PSTR("%d networks found:\n"), scanResult);
    // Print unsorted scan results
    for (int8_t i = 0; i < scanResult; i++) {
      WiFi.getNetworkInfo(i, ssid, encryptionType, rssi, bssid, channel, hidden);
      Serial.printf(PSTR("  %02d: [CH %02d] [%02X:%02X:%02X:%02X:%02X:%02X] %ddBm %c %c %s\n"),
                    i,
                    channel,
                    bssid[0], bssid[1], bssid[2],
                    bssid[3], bssid[4], bssid[5],
                    rssi,
                    (encryptionType == ENC_TYPE_NONE) ? ' ' : '*',
                    hidden ? 'H' : 'V',
                    ssid.c_str());
      delay(0);
    Serial.printf(PSTR("WiFi scan error %d"), scanResult);
  // Wait a bit before scanning again
  delay(5000);
dokus_23:
Do you mean you have the code uploaded to the NodeMCU board?
