Hello Folks,
Right now I am doing an university project which requires me to use an Arduino for sensing atmospheric pressure. I am using a sensor that represents the difference of pressure between his two inputs in form of two different inductances. While the difference rises or fall, one inductance increases and the other decreases. I did all the testing with a pressure generator and could verify that the inductances vary more or less between 7 mH and 10 mH in both sides with 10000 Pa applied to one input. Both inductances will show more or less 8 mH when there's not pressure difference.
So, in order to sense this with an Arduino, the first thing I did was create a small circuit in form of bridge, having the differential inductances and two equal resistances, and feed the system with an AC signal, so I can measure a voltage drop difference between the two bridge branches (Va and Vb), like the circuit image below:
The best result I could find, after testing different resistance/signal setups (which is the same of the image if I'm not mistaken) was to have a sine wave that varies between 4 Vpp (no pressure difference) and 7.2 Vpp (+10000 Pa difference).
Now I got stuck. I need to convert this sine wave into something the Arduino would be able to read (DC signal between 0 and 5 V). What would be the best option?
My advisor recommended using a comparator to convert the sine to a square wave and then have it through a Phase Locked Loop IC (4046)... I tried reading more about this approach but it honestly made no sense to me. I also tried some other options but had no success so far.
I would be thankful if anyone has any idea regarding such problem.
