Sensing stopped while running the mpu6050 DMP6 example
I'm going to print Roll, Pitch, and Yaw using Arduino and mpu6050.
For this, I am using the DMP6 example below.
I used this example as it is and it works well. However, the output stops after a while (within 1 minute) while outputting the sensor value.
I don't think there's a part in this example code where the print stops. (I'm not good at coding Arduino, so I'm not sure if this is right.)
May I know the expected cause of the this problem?
Thank you.
MPU6050_DMP6.ino (14.8 KB)
You can contact the author or his successor. I posted links from the link you supplied. They were at the bottom of the page. I gather they were just posted.
Note: additional details about this project can be found at https://www.i2cdevlib.com
Another note: this project has a fledgling successor that aims to address all of its shortcomings, which can be found at Perilib ยท GitHub
