Sensitive Analogread help.
Hi!
I was just testing my automatic beverage pump i have been prototyping and found an error. This code below works perfect except that the analog inputs is very sensitive, if i just tap the arduino it will think i put a current on A0 or A1 and thus starting the sequence. Is there some way to add a threshold to the code where i atleast need 4volts for the digitalwrite would accept it as "HIGH"?. I wrote an alternative code also (Very far down) where i used a if statement, this works somehow but very randomly sometimes it works, sometimes it is reversed etc. Im sorry if this might be basic stuff but in the end im a complete noob and this is the first code i wrote on the arduino. Any help would be appreciated
Simple schematic
5v --> pushbutton --> analog input. digital output --> relay --> valve
int input0 = A0;    // select the input for each pushbutton
int input1 = A1;
int output0 = 13;   // select the output pin for the relay
int output1 = 12;
int val = 0;        // variable for reading the pin status
int buttonState = 0;
int lastButtonState = LOW;
  // declare the digitalpins as OUTPUTS:
  pinMode(input0, INPUT); //Cola
  pinMode(input1, INPUT); //Sprite
  pinMode(output0, OUTPUT); //Cola
  pinMode(output1, OUTPUT); //Sprite
void loop(){
  // Cola
  // read the state of the pushbutton value:
  buttonState = digitalRead(input0);
  if (buttonState == HIGH) {
    // turn relay on:
    digitalWrite(output0, HIGH);
    delay(5000);
  else {
    // turn Relay off;
    digitalWrite(output0, LOW);
   // Sprite
   buttonState = digitalRead(input1);
    // turn Relay on;
    digitalWrite(output1, HIGH);
    delay(5000);
  else {
    // turn Relay off;
    digitalWrite(output1, LOW);
Alternative Code
int input1 = A1;
int output1 = 12;
int value0 = 0;        // variable for reading the pin status
int value1 = 0;        // variable for reading the pin status
  analogReference(DEFAULT);
void loop(){
  // Cola
  int value0 = analogRead(input0);
  if(value0 > 700) digitalWrite(output0, HIGH);
  delay(5000);
  int value1 = analogRead(input1);
  if(value1 > 700) digitalWrite(output1, HIGH);
  delay(5000);
[code][quote]5v --> pushbutton --> analog input.
There's your problem. With the switch open the input floats. You need a pull-down resistor from the pin to ground:
5v --> pushbutton --> analog input --> 1K to 10K resistor --> Ground [/code]
