Sensitive on/off motion sensor?
Hello, I’m making a battery transmitter, and i need a switch/passive component without power consumption to activate the ic, by movement(like seismic activity by being carried).
Anyone know of such a component?
lots of sensors could be used. there is a spring in a tube. when the spring is disturbed it will touch the tube and send the signal. you have to use debounce in hardware or respond to a fast pulse. the switch resets with no motion.
I think orientation is also important. under compression, the spring may not touch the tube. a sideways tap might send a very strong signal.
http://www.aliexpress.com/store/product/Shock-Shake-Switch-Sensor-Module-kit-for-Arduino-AVR-PIC/607593_1413532270.html
keyes seems to make a variety of sensors. this is one they have in there kit.
Here are another couple of them:
http://www.engineeringshock.com/vibration-sensor-module---arduino.html
http://www.satistronics.com/arduino-shock-sensor-module-801s_p3075.html
