Sensor acting weird - 100% code issue
Hello.
While using this code below i am getting strange results.
I blocked calculations of HCSNR sensor after it has passed out of range (0-200 cm).
When i cover up one "hole" e.q. reciever the sensor blocks himself and asks for restart.
But when i just click 2 or 3 for measuring temperature or humidity it does the thing and i am able to press 4 to continue measuring distance.
BUT i really need it to do the thing while i press 1 for menu.
What is so different when i press 2 or 3 and the sensor is avaliable again, but when i press 1 it is not???
"this code" ?
AWOL:
"this code" ?
No, "this one" :smiley:
Well i thought u guys will be able to take a hint :stuck_out_tongue:
I guess not :slight_smile:
#include <Wire.h>
#include <Keypad.h>
#include <dht.h>
#define dht_apin A0 //výstup z DHT
#define trigPin 2 //výstup zo SNR
#define echoPin 3 //vstup do SNR
//#define BACKLIGHT_PIN 13
dht DHT;
float duration, distance;
//Nastavenie displeja
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
const uint8_t charBitmap[][8] =
  { 0xc, 0x12, 0x12, 0xc, 0, 0, 0, 0 },
  { 0x6, 0x9, 0x9, 0x6, 0, 0, 0, 0 },
  { 0x0, 0x6, 0x9, 0x9, 0x6, 0, 0, 0x0 },
  { 0x0, 0xc, 0x12, 0x12, 0xc, 0, 0, 0x0 },
  { 0x0, 0x0, 0xc, 0x12, 0x12, 0xc, 0, 0x0 },
  { 0x0, 0x0, 0x6, 0x9, 0x9, 0x6, 0, 0x0 },
  { 0x0, 0x0, 0x0, 0x6, 0x9, 0x9, 0x6, 0x0 },
  { 0x0, 0x0, 0x0, 0xc, 0x12, 0x12, 0xc, 0x0 }
const byte ROWS = 4; //4 rady
const byte COLS = 4; //4 riadky
byte rowPins[ROWS] = {39, 41, 43, 45}; //zapojenie radov klávesnice do Arduina
byte colPins[COLS] = {31, 33, 35, 37}; //zapojenie riadkov klávesnice do Arduina
char keys[ROWS][COLS] =
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'}, //definovanie znakov klávesnice
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
  Serial.begin (9600);
  lcd.begin(16, 4);
  int charBitmapSize = (sizeof(charBitmap ) / sizeof (charBitmap[0]));
  for ( int i = 0; i < charBitmapSize; i++ )
    lcd.createChar ( i, (uint8_t *)charBitmap[i] );
  lcd.home ();
  lcd.print("Diplomova praca");
  lcd.setCursor (0, 1);
  lcd.print(" Radovan MATEJ");
  lcd.setCursor (0, 2);
  lcd.print("System OK");
  lcd.setCursor (0, 3);
  lcd.print("Stlac tlacitko");
  delay(500); // System reboot
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(dht_apin, INPUT);
  pinMode(A1, OUTPUT); // LED pin
  pinMode(A2, OUTPUT); // LED pin
  pinMode(8, OUTPUT); //pin pre napájanie SNR
  digitalWrite(8, HIGH);
  digitalWrite(A1, LOW);
  digitalWrite(A2, LOW);
  pinMode(A7, OUTPUT);
  digitalWrite(A7, HIGH);
  pinMode(10, OUTPUT);
  digitalWrite(10, HIGH);
//LED SIGNAL
// digitalWrite(A1, HIGH); digitalWrite(A2, HIGH); delay(1000); digitalWrite(A1, LOW); digitalWrite(A2, LOW); delay(1000);
  char key = keypad.getKey();
  if (key)
//    Serial.println(key);
    switch (key)
      case '1': // MENU
        lcd.clear();
        lcd.home();
        lcd.print("Menu        - 1");
        lcd.setCursor(0, 1);
        lcd.print("Teplota     - 2"); //TEMPERATURE
        lcd.setCursor(0, 2);
        lcd.print("Vlhkost     - 3"); //HUMIDITY
        lcd.setCursor(0, 3);
        lcd.print("Vzdialenost - 4"); //DISTANCE
      case '2': //Teplota
        DHT.read11(dht_apin);
        lcd.clear();
        lcd.home();
        lcd.print ("Teplota"); //TEMPERATURE
        lcd.print(DHT.temperature);
        lcd.setCursor(6, 1);
        lcd.print("C");
        lcd.print("Stlac 1 pre menu"); //PRESS 1 FOR MENU
      case '3': //HUMIDITY
        lcd.clear();
        lcd.home();
        lcd.print("Vlhkost"); //HUMIDITY
        lcd.print(DHT.humidity+20);
        lcd.print("%");
        lcd.print("Stlac 1 pre menu");//PRESS 1 FOR MENU
      case '4': //RANGE
        lcd.clear();
        lcd.home();
        lcd.print("Vzdielenost"); //DISTANCE
        digitalWrite (echoPin, LOW);
        digitalWrite(trigPin, LOW);
        duration = 0;
        distance = 0;
        delayMicroseconds(2);
        digitalWrite(trigPin, HIGH);
        delayMicroseconds(10);
        duration = pulseIn(echoPin, HIGH);
        distance = (duration / 2) / 29.1;
        Serial.println(distance);
        Serial.println(duration);
        if (distance >= 200 || distance <= 0)
          lcd.clear();
          lcd.home();
          lcd.print("Vzdialenost"); //DISTANCE
          lcd.print("Mimo rozsah"); //OUT OF RANGE
          lcd.print("Restartujte ..."); //RESTART
          lcd.print("Stlacte  '*' "); //PRESS *
          lcd.print(distance, 2);
          lcd.print("cm");
          delay(1);
      case '*':
        lcd.home();
        lcd.clear();
        lcd.print ("Restartujem ...."); //RESTARTING
        lcd.print("Prosim cakajte ..."); // PLEASE WAIT
        digitalWrite(A7, LOW);
        delay (1000);
        lcd.clear();
        lcd.home();
        lcd.print("Teplota     - 2"); // TEMPERATURE
      default:
I translated what i think is needed in comments.
No ideas ? :o
I have an idea.
You describe what you expect to happen, what is actually happening, and how your expectations differ from your observations.
The most obvious difference is that case '1' does not read the sensor whereas cases '2' and '3' do
