Sensor application and voltage dividers
Hi all,
I am working on a project where im using a 12v sensor and connecting it to a 0-5v adc. the board with the adc im using has a 32.4k pull down resistor. I cannot modify the board
I dont know the sensors maximum output voltage, I have used it to measure up to 6.7v.
I would like to truncate the voltage from 6.7v down to 5v and adjust the transfer function. I have been doing this like so for some time:
image: Sensor 10k hosted at ImgBB — ImgBB
I am wondering what happens if i go with a voltage divider like so:
Image: Sensor vdivider hosted at ImgBB — ImgBB
I dont know why the images wont load, nor why arduino forum holds you hostage for 5 minutes between posts/edits..
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html
Can you post a link to data/spec of your sensor.
What model Arduino are you using and why don't you use its AtoD, analog input?
Thanks.. Tom.. :slight_smile:
That is not a voltage divider, the voltage divider was in the first diagram with the 10K and 32.4K resistors.
Why would it not be considered a voltage divider? The grounds do tie together at the end of it all
im_the_new_guy:
Because for it to be a voltage divider as shown, you would have to reverse the input and output.
aarg:
What if i move the 3.3k on the downside of the 10k?
If you move it to the other side of the 10K the yes it would be a voltage divider with 10K and the other resistor being 3K3 in parallel with 32K4.
