Sensor + Arduino Power Problems
I have a Arduino uno and everytime I hook the sensor to the 5V pin and The ground Pin the arduino shuts off. I have no clue why. This also happens with the 3v3 pin.
What is the sensor??? Link?
Weedpharma
MPU6050 http://www.newegg.com/Product/Product.aspx?Item=9SIA2E60ZS2416
Which pins are you attaching to 5v and Gnd? Vcc and Gnd are next to each other on the sensor module. Did you solder the header your self? I would suspect a solder bridge if you have attached Vcc to 5v and Gmd to Gnd.
