Sensor Array Request for Member '...' in '...' error message
Hello,
Apologies, this is the first time I have tried programming. I have the following sketch:
int pins = {0,1,2,3,4,5};
int *values = new int[6];
for (int i = 0; i < pins.length; i++) {
println(i);
To read input voltages 0-5V to the 6 analogue pins on my UNO R3 from IR Sensors (Pololu QTR-8A sensor array). I want this part of the sketch to read the values from the sensors - I will later develop this to control continuous rotation servos.
For the line:
I have the following error message:
"Request for member “length” in “pins”, which is of non-class type ‘int [6]’ ".
What needs to change?
Thank you.
This is C++, not Java. Please remember to use code tags when posting code.
Your code. Why do you think that an int array has a member named length?
Why are you dynamically allocating an array whose size never changes and which never goes out of scope?
