Sensor data loss while sending data via Wifi request - MPU6050 and MKR Wifi
Hi everybody,
I am new to programming and need some advice.
In my project I am using an Arduino MKR Wifi 1010 and a MPU 6050 sensor to send accelerometer data at about 80 Hz via Wifi to a server.
The data is temporarily stored in an array on the arduino memory and sent about every 3 seconds via HTTP request.
But here is the problem: during request time, the accelerometer data gets lost, which means i got gaps of about 150ms every 3 seconds. I want to detect steps and other biomedical parameters, so this makes my measurement inaccurate.
How can I adapt my code, so nothing gets lost?
Can I use the Fifo buffer on the MPU 6050 to store the missing data temporarily?
Are there other possible solutions?
Please helf me out, I am happy for any advice I can get.
#include <MPU6050_tockn.h>
#include <WiFiNINA.h>
MPU6050 mpu6050(Wire);
long timer = 0;
long interval = 11;
int counter = 0;
String d;
String dSend;
char server[] = "192.168.43.166";
char script[] = "/addarray.php";
char ssid[] = "EMAT";
char pass[] = "87654321";
int status = WL_IDLE_STATUS;
WiFiClient client;
    if (WiFi.status() == WL_NO_MODULE) {
            while (true);
    while (status != WL_CONNECTED) {
        status = WiFi.begin(ssid, pass);
        delay(2000);
    Wire.begin();
    mpu6050.begin();
    mpu6050.calcGyroOffsets(true);
    mpu6050.update();
    if(millis() - timer > interval){
        int t = timer;
        int z = mpu6050.getAccX();
        timer = millis();
        if (counter < 1) {
            d.concat("data=[[");
            d.concat(t);
            d.concat(",");
            d.concat(z);
            d.concat("],[");
            counter++;
        } else if (counter <= 288) {
            d.concat(t);
            d.concat(",");
            d.concat(z);
            d.concat("],[");
            counter++;
            d.concat(t);
            d.concat(",");
            d.concat(z);
            d.concat("]]");
            dSend = d;
            d.remove(0);
            counter = 0;
    if (dSend.length() > 10) {
        if (client.connect(server,80)) {
            client.print("POST ");
            client.print(script);
            client.println(" HTTP/1.1");
            client.print("Host:");
            client.println(server);
            client.println("Content-Type: application/x-www-form-urlencoded");
            client.print("Content-Length:");
            client.println(dSend.length());
            client.println();
            client.print(dSend);
            client.stop();
            dSend.remove(0);
It looks like the FIFO is intended to help out with timing issues, so I'd be inclined to figure out how to enable it and then burst read your data from it.
