I am totally new to Arduino please correct me if my questions are wrong. Doing a project to send sensor data between two Arduino Uno using NRF24L01.
Here I am using tilt sensor at sender side and external power supply using 9v battery. I want data at receiver side when tilt sensor is activated along with that every 1 hours I need to know the sender batter status at receiving side.
I request if someone has similar example code for this project to please share or if someone has done this project please drop me your contact details so that I can contact personally and get help.
Wireless problems can be very difficult to debug so get the wireless part working on its own before you start adding any other features.
The examples are as simple as I could make them and they have worked for other Forum members. If you get stuck it will be easier to help with code that I am familiar with. Start by getting the first example to work
Thank you. As i said i ma new to arduino i am getting confuse how to write the transmitter code for both sensor data and battery status. because at receiver side i need to know two outputs one is sensor and another is sender side battery voltage.
so please help me with the code if you have any example
bmg1234:
I have already given you a link to my examples. In the 6 minutes between my Reply #1 and your Reply #2 I doubt very much if you had a chance to study and try my examples. If you can't make sense of them after 6 hours of intensive study then questions would be reasonable.
