Hello everybody.
I’m working on a project where I collect sensor data periodically, then save it on an SD card and finally send several measurements together with the GSM module to a web server.
The goal is to take a measurement every hour. The transmission interval should be up to 3 weeks. So I would like to transmit the accumulated measurement data once every 3 weeks to a web server. In addition, I do not have just one measurement unit, but it can be several measurement units. The measuring units will be connected to the central unit in order to store and transmit the data there.
Number of measuring units: Up to 10
Number of measurements per day per measuring unit: Up to 24 (1 hour interval)
Number of days per transmission interval: Up to 21 days (3 weeks)
→ Maximum number of measurements per transmission: 102421 = 5040 measurements
At the moment I have a working script to send ONE measurement in json format via GSM to a database. I use the HTTP POST method and a php file, which reads out the data and writes it to the database.
I am saving a measurement already in the right format (json) to send it later.
A measurement looks like this on the SD card:
{“DT”: 20171214155344,“T”: 23.31,“H”: 43.85,“VB”: 6.77,“R”: 442411170.00}
DT=DateTime (Timestamp from RTC), T=Temperature, H=Humidity, VB=Battery voltage, R=Resistance
I tend to save the data in the future in csv format on the SD card. The SD card should also serve as a backup if no radio connection is available at the current location.
The problem I have now recognized that if I want to transmit many measurements in this way, it will take a long time for everything to be transmitted via GSM. The main reason for this is the large delays it needs after the AT commands AT + HTTPACTION (4sec) and AT + HTTPREAD (3sec). Below you can see a section of the GSM send function, where these AT commands are executed.
for (int i = 0; i < numMeas; i++) {// numMeas=number of measurements to send
gsm.SimpleWrite("AT+HTTPDATA="); //
delay(200);
gsm.SimpleWrite(toTransmitLength[i]); //length of one measurement i
delay(200);
gsm.SimpleWriteln(", 1000");
delay(300);
gsm.SimpleWriteln(*toTransmit[i]); //measurement i
gsm.SimpleWriteln("AT+HTTPACTION=1");
delay(4000);
gsm.SimpleWriteln("AT+HTTPREAD");
delay(3000);
What I would like to know is how I can transfer as much data as quickly as possible in order to achieve low energy consumption (battery powered). I suspect the method with HTTP Post and the file format json may not be suitable for it. I am looking for a better way to transfer this number of measurements to a MySQL database.
I use the following components:
- SIM900 GPRS/GSM Board Quad-Band Module Kit for Arduino, from sainsmart.com
- Adafruit Assembled Data Logging shield for Arduino + 4GB SD Card
- Arduino Mega 2560 Dev. Board
- Complete code (record values, save to SD card, send with GSM module)
