Hello everybody,
I am in big trouble, that's three days I did manage to do anything ...
I installed the new version of Arduino is since I have all these error message appears:
Warning: platform.txt heart of Arduino Boards i586 'Contains recipe.ar.pattern = "{} {compiler.ar.cmd compiler.path}"} {compiler.ar.flags "build.path {} / {} ARCHIVE_FILE ""} {object_file "exceeded automatically converted recipe.ar.pattern =" {} {compiler.ar.cmd compiler.path} "{compiler.ar.flags}"} {archive_file_path "" object_file {} ". Setting a level that heart is advised.
Warning: platform.txt heart of Arduino Boards i686 'Contains recipe.ar.pattern = "{} {compiler.ar.cmd compiler.path}"} {compiler.ar.flags "build.path {} / {} ARCHIVE_FILE ""} {object_file "exceeded automatically converted recipe.ar.pattern =" {} {compiler.ar.cmd compiler.path} "{compiler.ar.flags}"} {archive_file_path "" object_file {} ". Setting a level that heart is advised.
Intel card: i586: izmir_fg option does not define "build.board". It is set automatically: I586_IZMIR_FG
Intel card: i586: izmir_fd does not define "build.board" option. It is set automatically: I586_IZMIR_FD
Intel card: i686: izmir_ec does not define "build.board" option. It is set automatically: I686_IZMIR_EC
CAUTION: The category '' in DallasTemperature library is not valid. Definition of 'Uncategorized'
CAUTION: The category '' in the EEPROM library is not valid. Definition of 'Uncategorized'
CAUTION: The category '' in the Ethernet library is not valid. Definition of 'Uncategorized'
CAUTION: The category '' in EthernetShield library is not valid. Definition of 'Uncategorized'
CAUTION: The category '' in the OneWire library is not valid. Definition of 'Uncategorized'
CAUTION: The category '' in the SD library is not valid. Definition of 'Uncategorized'
CAUTION: The category '' in the SPI library is not valid. Definition of 'Uncategorized'
CAUTION: The category '' in the Servo library is not valid. Definition of 'Uncategorized'
CAUTION: The category '' in SoftwareServo library is not valid. Definition of 'Uncategorized'
CAUTION: The category '' in TimerOne library is not valid. Definition of 'Uncategorized'
CAUTION: The category '' in USBHost library is not valid. Definition of 'Uncategorized'
CAUTION: The category '' in the library WiFi is invalid. Definition of 'Uncategorized'
In file included from C:\Users\viann\Documents\Arduino\libraries\Seeed_Grove_Temperature_And_Humidity_Sensor_g-master\examples\test_seeed_gp\test_seeed_gp.ino:4:0:
C:\Users\viann\Documents\Arduino\libraries\Seeed_Grove_Temperature_And_Humidity_Sensor_g-master/SeeedDHT.h:17:2: error: #error "CPU SPEED NOT SUPPORTED"
exit status 1
Error when compiling.
Then, for with the new version of the Arduino starter kit example are no longer Through the Library alor that it is installed in the library.
last point is as you voyer module: Seeed_Grove_Temperature_And_Humidity_Sensor_g-master
It does not work. I think it's because he can not find the file DHT alor there is ...
help please ...
Arduino Version: 1.6.6
Intel Version Images Edison edison-iotdk-image-280915
