Sensor for detecting marbles (Sensor para detectar bolas de gude).
English:
I need a sensor that can detect a specific marble, preferably by color (or shape). For example, I place several marbles in a structure so that they compete with each other at speed. I need to find that it arrived first and that the Arduino write me the time and position without error. If you know any sensor please post here.
It can be something very similar to these sensors indicated in the image and the link: https://youtu.be/AxADr7AMtSA
Português do Brasil:
Preciso de um sensor que consiga detectar uma bola de gude específica, de preferência pela cor (ou da forma que der). Por exemplo, coloco várias bolas de gude numa estrutura para que compitam entre si em velocidade. Preciso encontrar qual chegou primeiro e que o Arduino escreva para mim sem erro o tempo e a posição de cada uma delas. Se vocês conhecerem algum sensor por favor, poste a resposta aqui.
Pode ser algo muito parecido com esses sensores indicados nas imagens aí abaixo (clique na foto 1 e na foto 2 para baixar as fotos) e/ou no link: https://youtu.be/AxADr7AMtSA
Gente, descobri num vídeo que esses sensor existe e provavelmente está presente nos kits de brinquedos de bolas de gude, vejam: Marble Run in the Garden - YouTube
Arrange for them to all drop down the same hole, stacking up. Record the time when each drops. The position order will be obvious.
jremington:
English:
Good tip buddy, in the video, I already noticed this, the marbles only mark time at specific moments of the track. The problem now is to detect who they are, in the right order, so that the Arduino can compute accurate data. Furthermore, I need to know how to differentiate them. I suspect that the structures I marked in the photo are just plastic parts of the track and these structures are not sensors. But I noticed a new structure in this video: https://youtu.be/1H3UUVwia1I
Is this the sensor that identifies each marble?
Boa dica amigão, no vídeo, eu já notei isso, as bolinhas de gude só demarcam tempo em momentos específicos da pista. O problema agora é detectar quem são elas, na ordem certa, para que o Arduino possa computar dados precisos. Além disso preciso saber como diferenciá-las. Eu desconfio que as estruturas que marquei na foto são apenas partes de plástico da pista e essas estruturas não são sensores. Porém percebi uma nova estrutura nesse vídeo: https://youtu.be/1H3UUVwia1I
Será que esse é o sensor que identifica cada bolinha de gude?
