Sensor Hall Effect SS461C
Hello, I have a hall effect sensor SS461C handy, and I would like to use it for counting the rpm of a rotating disk.
Since it is a latching sensor, I would use 4 magnets place at quarters of the disk to do not create too much unbalance.
The datasheet is here.
I am not confident on the wiring.
I create 6 alternatives on the attached figure.
The number 1 without any resistance is what I was thinking to use since the max output current is 20mA, which should be ok for arduino pins. Alternative, the number 6 is what looks similar to the schematics on the datasheet but I cannot understand the difference between 1 and 6.
But since the actual output current depends on the magnets (if I understood well) and I do not know their magnetic field yet, I have seen online schematics with a 10komh resistor.
I do not know where this number comes from, I have tried to use the omh's law but I am clueless.
Moreover, I cannot understand if the figures from 2 to 5 makes some differences or if they are all the same.
Could you help me with that? thanks
None of those will do.
Your sensor has open circuit collector output.
Tom... :slight_smile:
TomGeorge:
Hi Tom, thank you for your reply,
no idea why your wiring works but I am sure it is right.
I attached the figure with the new configuration and the block diagram from the datasheet (where the output is wired to the ground).
How to calculate the resistance I need?
Thank you
Sorry no, its like this.
AntroxEv:
No calculation, really. The only thing that cna be calculated is the absolute minimum: you mentioned maximum 20 mA current, so with a 5V supply that's giving you the minimum resistance of 250Ω. But that would make for a ridiculously strong pull-up, so we never do that. 10k is a far more sensible value, so the sensor's pin has to sink only 0.5mA. Actually 10k is the de-facto default value for a pull-up (or pull-down) resistor.
Or simply use the internal pull-up (typical 20-30kΩ) by setting the pinMode to INPUT_PULLUP.
Just remember when a south pole passes the output will latch Low until a north pole passes the sensor and the sensor will latch High so using 4 magnets you need two north and two south poles.
South Pole toward IC:
Output = Low
North Pole toward IC:
Output = High
You will have 2 PPR (Pulses Per Revolution).
Ron
Ron_Blain:
Output = Low
Output = High
Ron
Yes, I though it.
I need just to reverse the faces of the magnets, doesn't it?
wvmarle:
A couple of additional questions:
  1. If 5V is the voltage supply by Arduino, doesn't the hall effect give a further contribution (5V+xx?) ?
  2. Will I end with my diagram number 2 if I am using the internal pull-up ?
Thanks
AntroxEv:
Thanks
Not sure what you mean but I would say No, your sensor is 5 volt powered by your arduino board. That is Vcc to your sensor and the Arduino board Ground and the sensor Grouind are tied as a Common Ground.
Yes, depending on how the magnets are configured but a passing south latches and a passing north un latches so you want your sensor seeing S/N/S/N resulting in 2 pulses per revolution.
Ron
Ron_Blain:
Ron
I though the Hall Effect produces an increment of the voltage due to the magnetic field.
Anyway, I have tested the configuration tested by Tom and works fine.
thank you all for your support
AntroxEv:
Nope, unlike an inductive pick up. The Hall sensor is powered. You apply 5 volts between VCC and Ground pins and the Vout or Out pin gives you about 5 volt pulses.
Ron
Just to conclude with the code for the counter (I haven't test yet):
const int pinSwitch = 2; \\connected to the Hall Sensor output
volatile byte state = LOW;
int revs = 0;
float RPM = 0;
int t = 60; //duration of the test in seconds
  pinMode(pinSwitch , INPUT);
  attachInterrupt(digitalPinToInterrupt(pinSwitch ), counter, RISING);
  RPM=revs/2*t/60; // since I have 4 magnets
  Serial.println(RPM);
void counter() {
  revs = revs ++;
I used the keyword RISING for attachInterrupt(), hence my function counter() should be called only when the Hall Effect sensor goes from LOW to HIGH (to compensate the fact ideally I would need of a non-latching sensor).
I need to find the way to record the time in order that the time t is a variable and not a constant.
Do I need to use a RTC module or just the built-in timer in Arduino?
I have to mention that I will adapt this code to work with a code for the stepper motor and I need to avoid any undesired delay that interferes with the speed of the stepper.
Thanks
While I am far from a programming type I can tell you that code will not load:
const int pinSwitch = 2; \connected to the Hall Sensor output
Your slashes for the comment are backwards. Change that and the code will load but regardless of input, I used an Arduino Uno and a function generator, produces 0.00 in the serial monitor. My best guess is because:
int revs = 0;
Nothing changes that zero. Also remember you do have 4 magnets which will result in two pulses per revolution. That part would have went better using a non-latching Hall Effect Sensor. Again, I am not a programmer type so hopefully someone will come along and make some good suggestions.
Ron
Ron_Blain:
int revs = 0;
Ron
Thank you for spotting the mistake. I have changed them accordingly.
void counter() {
  revs = revs ++;
the variable revs will be changed when the function counter is called.
I will test it soon and I post the outcome here if there is any thing to amend.
Thanks
