buenos dias, necesito ayuda con esta programacion.....
necesito explicarlo pero no conozco algunas librerias y no entiendo la programacion..... si podria alguien explicarme paso a paso graciasss
#include <LiquidCrystal.h>
LiquidCrystal lcd(13,12,11,10,9,8);
const int hallSensorPin = 2; // connect the hall effect sensor on pin 2
const unsigned long sampleTime = 1000;
const int maxRPM = 1260; // maximum RPM for LCD Bar
int rpmMaximum = 0;
pinMode(hallSensorPin,INPUT);
lcd.begin(16, 2);
lcd.print("Initializing");
lcd.clear();
delay(100);
int rpm = getRPM();
if (rpm > rpmMaximum) rpmMaximum = rpm;
lcd.clear();
displayRPM(rpm);
displayBar(rpm);
int getRPM()
int count = 0;
boolean countFlag = LOW;
unsigned long currentTime = 0;
unsigned long startTime = millis();
while (currentTime <= sampleTime)
if (digitalRead(hallSensorPin) == HIGH)
countFlag = HIGH;
if (digitalRead(hallSensorPin) == LOW && countFlag == HIGH)
count++;
countFlag=LOW;
currentTime = millis() - startTime;
int countRpm = int(60000/float(sampleTime))*count;
return countRpm;
void displayRPM(int rpm)
lcd.clear();
lcd.setCursor(0, 0);
lcd.print(rpm,DEC);
lcd.setCursor(7,0);
lcd.print(rpmMaximum, DEC);
lcd.setCursor(13,0);
lcd.print("MAX");
Serial.print("RPM = ");
Serial.print(rpm);
Serial.print(" MAX RPM = ");
Serial.println(rpmMaximum);
void displayBar(int rpm)
int numOfBars=map(rpm,0,maxRPM,0,15);
lcd.setCursor(0,1);
if (rpm!=0)
for (int i=0; i<=numOfBars; i++)
lcd.setCursor(i,1);
lcd.write(1023);
