sensor HIH 43030 sparkfun [fr]
Bonjours, pouvez vous m'aider à comprendre le programme svp. C'est pour mon bac , je dois faire un programme pour mesurer la tempérarure, humidté etc. Je voudrais qu'on m'explique la partie avec les calculs. Merci de votre aide :blush:
int HIH4030_Pin = A0; //analog pin 0
void setup(){ Serial.begin(9600); }
void loop(){
//To properly caculate relative humidity, we need the temperature. float temperature = 25; //replace with a thermometer reading if you have it float relativeHumidity = getHumidity(temperature);
Serial.println(relativeHumidity);
delay(500); //just here to slow it down so you can read it }
float getHumidity(float degreesCelsius){ //caculate relative humidity float supplyVolt = 5.0;
// read the value from the sensor: int HIH4030_Value = analogRead(HIH4030_Pin); float voltage = HIH4030_Value/1023. * supplyVolt; // convert to voltage value
// convert the voltage to a relative humidity // - the equation is derived from the HIH-4030/31 datasheet // - it is not calibrated to your individual sensor // Table 2 of the sheet shows the may deviate from this line float sensorRH = 161.0 * voltage / supplyVolt - 25.8; float trueRH = sensorRH / (1.0546 - 0.0026 * degreesCelsius); //temperature adjustment
return trueRH; }
Est google brisé dans votre pays ?
Please rephrase your question in English on the international part of the forum...
