Sensor Loadcell
Hi familllies arduino iam using loadcell for getting weigh, anybody know how i can find some
manufacturing to doing a balance for me with my loadCell sensor
What is the problem ? (what do you want to do?)
Check if the following schematic appears a bit helpful. |500x289
That's a circuit for the ATmega32, not the ATmega328.
The bit in the middle is an HX710B high-resolution ADC (https://img.ozdisan.com/ETicaret_Dosya/470782_5454613.PDF)
Typically people here have used an HX711 ADC chip, which are available from various vendors for use with Arduinos.
m328 does not have enough IO lines to be a part of a single chip based Digital Weighing Machine design. However, any of its four IO lines could be decoded to get 16 lines for the cc-pins of the 16x7-segment display device.
HX710B is an 8-pin low cost 24-bit ADC; whereas, HX711 is a 16-pin 24-bit device and more expensive than HX710B..
knut_ny: What is the problem ? (what do you want to do?)
I just want to do a balance any Loadcell an i want a costumer to do the box for me.
Contact manufacturing companies for enclosures.
