Sensor node does not send data after sleep
Hi guys,
Trying to put sensor node to sleep and after sleep period send Atmega 328p- PU internal temperature sensor data to master.
Slave code here:
#include <RF24.h>
#include <SPI.h>
#include <nRF24l01.h>
#include <printf.h>
#include <avr/io.h>
#include "LowPower.h"
#include <avr/wdt.h>
#define CE_PIN   9
#define CSN_PIN 10
const byte thisSlaveAddress[5] = {'R','x','A','A','A'};
RF24 radio(CE_PIN, CSN_PIN);
volatile char sleepCnt = 0;
char dataReceived[10]; // this must match dataToSend in the TX
bool newData = false;
    Serial.println("SimpleRxAckPayload Starting");
    radio.begin();
    radio.setDataRate(RF24_2MBPS);
    radio.openReadingPipe(1, thisSlaveAddress);
    radio.enableAckPayload();
    radio.startListening();
  system_sleep();
  getData();
  showData();
void getData() {
    if ( radio.available() ) {
        radio.read( &dataReceived, sizeof(dataReceived) );
        updateReplyData();
        newData = true;
void showData() {
    if (newData == true) {
        int temperatura = GetTemp();
        int ackData[1] = {temperatura};
        Serial.print("Data received ");
        Serial.println(dataReceived);
        Serial.print(" ackPayload sent ");
        Serial.println(ackData[0]);
        newData = false;
void updateReplyData() {
    radio.writeAckPayload(1, &ackData, sizeof(ackData)); // load the payload for the next time
double GetTemp(void)
  unsigned int wADC;
  double t;
  // The internal temperature has to be used
  // with the internal reference of 1.1V.
  // Channel 8 can not be selected with
  // the analogRead function yet.
  // Set the internal reference and mux.
  ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));
  ADCSRA |= _BV(ADEN);  // enable the ADC
  delay(20);            // wait for voltages to become stable.
  ADCSRA |= _BV(ADSC);  // Start the ADC
  // Detect end-of-conversion
  while (bit_is_set(ADCSRA,ADSC));
  // Reading register "ADCW" takes care of how to read ADCL and ADCH.
  wADC = ADCW;
  // The offset of 324.31 could be wrong. It is just an indication.
  t = (wADC - 324.31 ) / 1.22;
  // The returned temperature is in degrees Celcius.
  return (t);
 void system_sleep(){
    LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_OFF);
    Serial.println("I`m awake!");
This code results like this:
results
It looks like that chip does not have enough time to do tasks after sleeping, any ideas how to modify the code to let the node do all wake routines(send data)?
You only send the data if you received anything. The problem is that the hardware doesn’t have time to receive anything as it woke up a few micros before. You should overthink the concept again. Keep in mind that the hardware cannot receive anything while the processor sleeps.
The base is pinging Slaves at 4times per second and catches every Slave that is not in the sleep mode.
res4 res5
I guess you’re missing them most of the time. If that’s OK for your project, go ahead.
