system
February 8, 2012, 7:56pm
1
Hi there everybody
i am trying to make a wall avoiding robot using a HC-SR04 ultrasonic sensor, a dagu channel4, a dagu rover 5 and a servo.
but is isn't going that well.
i want to let the ultrasonic sensor to continuously (or take very fast samples)meassure the distance in front of it while it is driving forward.
and when it get's below a set distance to stop the sensor reading and move the servo to the right and meassure the distance, then move to the left and meassure the distance.
and then decide which way to go.
so far i did manage to make it stop when there is a wall in front of it.
but when i try to move the servo, the servo goes all crazy, because it keeps meassuring and then it thinks the distance is more then the set distance and so moves the servo back.
this is my code so far
#include "Ultrasonic.h"
#define TRIG_PIN 6
#define ECHO_PIN 7
Ultrasonic OurModule(TRIG_PIN, ECHO_PIN);
#define PwmPinMotorA 53
#define PwmPinMotorB 51
#define DirectionPinMotorA 52
#define DirectionPinMotorB 50
int pos = 0;
#include <Servo.h>
Servo myservo;
pinMode(PwmPinMotorA, OUTPUT);
pinMode(PwmPinMotorB, OUTPUT);
pinMode(DirectionPinMotorA, OUTPUT);
pinMode(DirectionPinMotorB, OUTPUT);
myservo.attach(9);
void forward(){
digitalWrite(DirectionPinMotorA, HIGH);
analogWrite(PwmPinMotorA, 150);
digitalWrite(DirectionPinMotorB, LOW);
analogWrite(PwmPinMotorB, 150);
void backward(){
digitalWrite(DirectionPinMotorA, LOW);
digitalWrite(DirectionPinMotorB, HIGH);
void left(){
void right(){
analogWrite(PwmPinMotorA, 255);
analogWrite(PwmPinMotorB, 255);
void pause(){
analogWrite(PwmPinMotorA, 0);
analogWrite(PwmPinMotorB, 0);
void pos1() {
OurModule.Ranging(CM);
void pos2() {
pos = OurModule.Ranging(CM);
myservo.write(90);
if (pos <30) {
forward();
else{
pause();
myservo.write(10);
you must make a statemachine, here the concept, not complete but you should get the idea
int state = MOVING;
switch (state)
case MOVING:
doMove();
case DETERMINE:
doDetermine();
default:
stop(); // for safety
doMove()
distance = Measure();
if (distance < 30)
state = DETERMINE;
stop();
forward();
doDetermine()
// rotate servo left
distanceLeft = Measure();
// rotate servo right
distanceRight = Measure();
if (distanceLeft <= distanceRight)
right();
// delay(100); ???
left();
// delay(100); ???
state = MOVING;
YOu can make the doDetermine() more intelligent, not just looking left and right but at every angle and choose the one with the most space. And of course it should move backwards if there is no left or right space.... (homework)
system
February 8, 2012, 9:27pm
3
thank you very much
i will go work on that, and probably upload it by suaterday
system
February 9, 2012, 5:56pm
4
I have tried to fit a switch case machine in my code and i came up with this so far.
but it doesn't work yet
the error i am getting is this one:
In function 'void doMove()':
error: void value not ignored as it ought to be In function 'void doDetermine()':
At global scope:
In function 'void loop()':
and an other error i am getting is that it can't find MOVING in: int state = MOVING ;
#define TRIG_PIN 6
#define ECHO_PIN 7
int pos = 0;
#include <Servo.h>
Servo myservo;
int distance = 0;
int distanceLeft = 0;
int distanceRight = 0;
myservo.attach(9);
void forward(){
void backward(){
void left(){
delay(300);
void right(){
delay(300);
void pause(){
void Measure() {
void doMove()
if (distance < 30)
state = doDetermine;
stop();
forward();
void doDetermine() // optie 2 het bepalen van de afstand links en rechts.
myservo.write(10);
delay(400);
delay(20);
myservo.write(170);
delay(400);
right();
left();
state = MOVING;
switch (state)
case MOVING: // optie 1 rijden
doMove();
case doDetermine: // optie 2 afstanden bepalen
doDetermine();
default: // standaard: sta stil
You need to define MOVING and DETERMINE (and use it) e.g.
#define MOVING 1
#define DETERMINE 2
You have tried to use doDetermine instead of DETERMINE as Robtillart had it.
system
February 10, 2012, 3:27pm
6
void Measure() {
Measure the distance, but don't return the distance. Now, there's a useful function!
system
February 10, 2012, 5:18pm
7
i noticed too that i forgot the void's before Determine etc
i changed the code again and made this of it
but now getting this error:
error: declaration does not declare anything In function 'void Move()':
At global scope:
and the this line is then highlighted: void Measure() {
#define TRIG_PIN 6
#define ECHO_PIN 7
int pos = 0;
#include <Servo.h>
Servo myservo;
int distance = 0;
#define MOVING;
#define Measure;
#define Determine;
#define state;
myservo.attach(9);
void forward(){
void backward(){
void left(){
delay(300);
void right(){
delay(300);
void pause(){
void Measure() {
void Move()
if (distance < 30)
state = Determine;
stop();
forward();
void Determine()
myservo.write(10);
delay(400);
delay(20);
myservo.write(170);
delay(400);
right();
left();
state = MOVING;
int state = MOVING;
switch (state)
case MOVING:
Move();
case Determine:
Determine();
default:
stop();
system
February 10, 2012, 5:34pm
8
Unless you really know what you're doing, don't put semicolons on #defines
system
February 10, 2012, 5:42pm
9
deleted the semicolens. but still getting the same error.
could my changing of the cases be wrong ?
system
February 10, 2012, 5:44pm
10
What is "Measure"?
A function, or an empty macro?
system
February 10, 2012, 5:50pm
11
with measure, it should meassure the distance with an ultrasonic sensor.
when i replace all the Measure(); for just OurModule.Ranging(CM); (i think this might just be easier)
when i compile i get:
error: expected primary-expression before '=' token At global scope:
with state = Determine; highlighted. removing the semicolon doesn't do anything
system
February 10, 2012, 5:54pm
12
state is a macro, you can't assign a value to it.
Post your code.
system
February 10, 2012, 5:55pm
13
#define state;
even with the semicolon defines a name, not a variable where you can store a value.
Well, of course you do. Removing the ; did something (useful), just not what you wanted.
Why are you using #define at all?
system
February 10, 2012, 5:56pm
14
#define TRIG_PIN 6
#define ECHO_PIN 7
int pos = 0;
#include <Servo.h>
Servo myservo;
int distance = 0;
#define MOVING
#define Determine
#define state
myservo.attach(9);
void forward(){
void backward(){
void left(){
delay(300);
void right(){
delay(300);
void pause(){
void Move()
distance = OurModule.Ranging(CM);
if (distance < 30)
state = Determine;
stop();
forward();
void Determine()
myservo.write(10);
delay(400);
distanceLeft = OurModule.Ranging(CM);
delay(20);
myservo.write(170);
delay(400);
distanceRight = OurModule.Ranging(CM);
right();
left();
state = MOVING;
int state = MOVING;
switch (state)
case MOVING:
Move();
case Determine:
Determine();
default:
stop();
system
February 10, 2012, 6:04pm
15
state = Determine;
You can't assign a value to a name!!!
Make state a variable:
int state = 0;
myservo.write(10);
delay(400);
delay(20);
myservo.write(170);
delay(400);
Have you timed how long it actually takes the servo to move?
#define Determine
void Determine()
Do you want Determine to be a name or a function? Don't try to use the same name for two different things.
system
February 10, 2012, 6:43pm
16
thank you very much PaulS and for the very clear explaination
this is my code now
although the Determine part isn't working yet, i think i will be able to fix it.
If you see the problem quick could you please tell me
#define TRIG_PIN 6
#define ECHO_PIN 7
int pos = 0;
#include <Servo.h>
Servo myservo;
int distance = 0;
int state =0;
myservo.attach(9);
void forward(){
void backward(){
void left(){
delay(300);
void right(){
delay(300);
void pause(){
void Move()
if (distance < 30)
state = 2;
pause();
forward();
void Determine()
myservo.write(10);
delay(400);
delay(20);
myservo.write(170);
delay(400);
right();
left();
state = 1;
int state = 1;
switch (state)
case 1: // 1 is moving
Move();
case 2: // 2 is Determine
Determine();
default:
pause();
system
February 10, 2012, 6:54pm
17
I don't think you ever run Determine(), unless I missed something:
int state = 1;
switch (state)
Move();
Determine();
default:
pause();
Set state to 1, then switch on state, so it's never going to be 2, then repeat.
system
February 10, 2012, 7:04pm
18
i see what you mean.
when i make it int state = 2;
it will only turn right or left.
what would be a good way to solve this ?
system
February 10, 2012, 7:11pm
19
You have two versions of state. One is global and gets updated in Move() and Determine(), the other is local to loop(), and only gets updated there. See what happens when you get rid of the 'int state = 1;' from the start of loop(), and initialise the global state to 1.
system
February 11, 2012, 12:58pm
20
thank you very much
it finally works
thanks every body for helping me out
this is my final code:
#define TRIG_PIN 6
#define ECHO_PIN 7
int pos = 0;
#include <Servo.h>
Servo myservo;
int distance = 0;
int state = 1;
myservo.attach(9);
void backword(){
void forward(){
void left(){
delay(300);
void right(){
delay(300);
void pause(){
void Move()
if (distance < 30)
state = 2;
pause();
forward();
void Determine()
myservo.write(10);
delay(400);
delay(20);
myservo.write(170);
delay(400);
delay(20);
myservo.write(90);
right();
left();
state = 1;
switch (state)
Move();
Determine();
default:
pause();
