SENSOR PING))) QUESTION
I GOT A PING))) SENSOR YESTERDAY
NOW I KNOW HOW DOES IT WORK
BUT I NOW, I NEED TO KNOW WHAT SHOULD I DO, TO TURN ON AN LED OR MOTOR WHEN THE SENSOR REACHES IN THE MIDDLE OF TWO NUMBERS.
WHAT SHOULD I CHANGE IN THE CODE
IF YOU DONT REALLY UNDERSTAND WHAT I MEAN, POST A COMMENT
where is the code?
/* Ping))) Sensor
This sketch reads a PING))) ultrasonic rangefinder and returns the
distance to the closest object in range. To do this, it sends a pulse
to the sensor to initiate a reading, then listens for a pulse
to return. The length of the returning pulse is proportional to
the distance of the object from the sensor.
The circuit:
  • +V connection of the PING))) attached to +5V
  • GND connection of the PING))) attached to ground
  • SIG connection of the PING))) attached to digital pin 7
created 3 Nov 2008
by David A. Mellis
modified 30 Jun 2009
by Tom Igoe
This example code is in the public domain.
// this constant won't change. It's the pin number
// of the sensor's output:
const int pingPin = 7;
// initialize serial communication:
// establish variables for duration of the ping,
// and the distance result in inches and centimeters:
long duration, inches, cm;
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
// The same pin is used to read the signal from the PING))): a HIGH
// pulse whose duration is the time (in microseconds) from the sending
// of the ping to the reception of its echo off of an object.
pinMode(pingPin, INPUT);
duration = pulseIn(pingPin, HIGH);
// convert the time into a distance
inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
Serial.print(inches);
Serial.print("in, ");
Serial.print(cm);
Serial.print("cm");
delay(100);
long microsecondsToInches(long microseconds)
// According to Parallax's datasheet for the PING))), there are
// 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
// second). This gives the distance travelled by the ping, outbound
// and return, so we divide by 2 to get the distance of the obstacle.
// See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
if (cm > minDistance && cm < maxDistance){
//turn led on
@OP: Please don't shout, and when posting code, use the # icon on the toolbar to put the code into a code box.
but can you put this somewhere on the code and post it so its gonna be easy for me to understand
and then i will try it
it's easy, and i won't code for you, unless you pay me :grin:
because im a 13 years old beginner.
and i really need help so that i will be able to make a robot.
and can a little part of code can be moved anywhere else and will it still work? :fearful:
ok, it's not working because of the cm or inche. :0
is there something else that can replace the cm or inche :relaxed:
Furlongs? What you have written doesn't make sense. Could you tell us what you think the problem is?
i think the problem is that my arduino uno cant read the cm and inches.i just need help for something that can replace the cm and inches
what i have written is:
/* Ping))) Sensor
The circuit:
created 3 Nov 2008
by David A. Mellis
by Tom Igoe
pinMode (13,OUTPUT);
Serial.print(cm);
Serial.print("cm");
delay(100);
if ( pingPin,_______________ )
digitalWrite(13,HIGH);
digitalWrite(13,LOW);
Please back to your last post,click on "modify", then highlight the code, then click on the # icon on the editor's toolbar.
Then click on "save".
Well of course it can't.
/* Ping))) Sensor
The circuit:
http://www.arduino.cc/en/Tutorial/Ping
created 3 Nov 2008
by David A. Mellis
by Tom Igoe
Serial.print(cm);
Serial.print("cm");
delay(100);
doned
No, not the "quote" icon, the Code (#) icon.
You can go back and modify old posts.
Why do you think that?
well if ( pingPin,_______________ ) i don't know what does, but your arduino can read the ms of the ping, and can translate this time in cm/inches
with the first code (that was working, right?) you can read in the serial monitor the output (distance in inch and cm), take a look if this data is good.
yeah your right, :smiley:
but can you send and example of it, a little bit modified, so i will understand it clearly :relaxed:
I don't understand what this is meant to signify. It doesn't look like C.
Please will you go back over your earlier posts, highlight the code, then click on the # icon. Then click "save".
Get rid of any "quote" tags, except where quotes are intended.
THANK YOU LESTO,
my PING))) SENSOR worked like a charm. :slight_smile: :smiley: :smiley: :smiley: :smiley: :smiley:
