It is not necessary for you to respond as above (I apologize for asking without first trying the code, I just did not want to burn anything, but, I see that it was simpler than I thought). I connect 4 sensors, everything works well, but, I still have a question.
The code that I use was this: Adafruit_VL53L0X/vl53l0x_dual.ino at master · adafruit/Adafruit_VL53L0X · GitHub
I add one more to have 3 sensors of it, my final code is this:
#include "Adafruit_VL53L0X.h"
// address we will assign if dual sensor is present
#define LOX1_ADDRESS 0x30
#define LOX2_ADDRESS 0x31
#define LOX3_ADDRESS 0x32
// set the pins to shutdown
#define SHT_LOX1 7
#define SHT_LOX2 6
#define SHT_LOX3 5
// objects for the vl53l0x
Adafruit_VL53L0X lox1 = Adafruit_VL53L0X();
Adafruit_VL53L0X lox2 = Adafruit_VL53L0X();
Adafruit_VL53L0X lox3 = Adafruit_VL53L0X();
// this holds the measurement
VL53L0X_RangingMeasurementData_t measure1;
VL53L0X_RangingMeasurementData_t measure2;
VL53L0X_RangingMeasurementData_t measure3;
Reset all sensors by setting all of their XSHUT pins low for delay(10), then set all XSHUT high to bring out of reset
Keep sensor #1 awake by keeping XSHUT pin high
Put all other sensors into shutdown by pulling XSHUT pins low
Initialize sensor #1 with lox.begin(new_i2c_address) Pick any number but 0x29 and it must be under 0x7F. Going with 0x30 to 0x3F is probably OK.
Keep sensor #1 awake, and now bring sensor #2 out of reset by setting its XSHUT pin high.
Initialize sensor #2 with lox.begin(new_i2c_address) Pick any number but 0x29 and whatever you set the first sensor to
void setID() {
// all reset
digitalWrite(SHT_LOX1, LOW);
digitalWrite(SHT_LOX2, LOW);
digitalWrite(SHT_LOX3, LOW);
delay(10);
// all unreset
digitalWrite(SHT_LOX1, HIGH);
digitalWrite(SHT_LOX2, HIGH);
digitalWrite(SHT_LOX3, HIGH);
delay(10);
// activating LOX1 and reseting LOX2
// initing LOX1
if(!lox1.begin(LOX1_ADDRESS)) {
Serial.println(F("Failed to boot first VL53L0X"));
while(1);
delay(10);
// activating LOX2
delay(10);
//initing LOX2
if(!lox2.begin(LOX2_ADDRESS)) {
Serial.println(F("Failed to boot second VL53L0X"));
while(1);
// activating LOX3
delay(10);
//initing LOX3
if(!lox3.begin(LOX3_ADDRESS)) {
Serial.println(F("Failed to boot 3 VL53L0X"));
while(1);
void read_dual_sensors() {
lox1.rangingTest(&measure1, false); // pass in 'true' to get debug data printout!
lox2.rangingTest(&measure2, false); // pass in 'true' to get debug data printout!
lox3.rangingTest(&measure3, false); // pass in 'true' to get debug data printout!
// print sensor one reading
Serial.print(F("1: "));
if(measure1.RangeStatus != 4) { // if not out of range
Serial.print(measure1.RangeMilliMeter);
Serial.print(F("Out of range"));
Serial.print(F(" "));
// print sensor two reading
Serial.print(F("2: "));
if(measure2.RangeStatus != 4) {
Serial.print(measure2.RangeMilliMeter);
// print sensor 3 reading
Serial.print(F("3: "));
if(measure3.RangeStatus != 4) {
Serial.print(measure3.RangeMilliMeter);
// wait until serial port opens for native USB devices
while (! Serial) { delay(1); }
pinMode(SHT_LOX1, OUTPUT);
pinMode(SHT_LOX2, OUTPUT);
pinMode(SHT_LOX3, OUTPUT);
Serial.println(F("Shutdown pins inited..."));
Serial.println(F("Both in reset mode...(pins are low)"));
Serial.println(F("Starting..."));
setID();
read_dual_sensors();
delay(100);
My question is, if I have 10 sensors, I just have to place the address in the following way:
#define LOX4_ADDRESS 0x33
#define LOX5_ADDRESS 0x34
#define LOX6_ADDRESS 0x35
#define LOX7_ADDRESS 0x36
#define LOX8_ADDRESS 0x37
#define LOX9_ADDRESS 0x38
#define LOX10_ADDRESS 0x39
Correme if I'm wrong, please.
I ask you to know if I should buy something more.
