Hello guys, im a bit confused in coding here. after i insert this “GetNumber()”(i got it here) in my sketch, my sensor stop updating over time. the only time it updates is when i input those 3 different numbers (v1-v3).
i want to keep my sensors updating after i inputted the 3 values. a bit confusing to me. thanks
#include "DHT.h"
#define DHTPIN 2 // what pin we're connected to
#define DHTTYPE DHT22 // DHT 22 (AM2302)
#define fan 4
#include <Wire.h>
#include <Keypad.h>
int v1 = 0;
int v2 = 0;
int v3 = 0;
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
DHT dht(DHTPIN, DHTTYPE);
//define the keypad
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte rowPins[ROWS] = {13, 12, 11, 10};
byte colPins[COLS] = {9, 8, 7, 6};
Keypad kpd = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
pinMode(fan, OUTPUT);
dht.begin();
lcd.begin(20,4);
lcd.clear();
float h = dht.readHumidity();
float t = dht.readTemperature(); //C
float f = dht.readTemperature(true); //F
float hic = dht.computeHeatIndex(t, h, false);
dht.read(h);
dht.read(t);
dht.read(f);
dht.read(hic);
lcd.setCursor(0,0);
lcd.print("Humidity: ");lcd.print(h);lcd.print(" > ");
lcd.setCursor(0,1);
lcd.print("Temp (C): "); lcd.print(t);lcd.print(" > ");
lcd.setCursor(0,2);
lcd.print("Temp (F): ");lcd.print(f);lcd.print(" > ");
lcd.setCursor(0,3);
lcd.print("Heat Index: ");lcd.print(hic);
// Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t)) {
lcd.print("Failed to read from DHT sensor!");
return;
if(t > v1) {
digitalWrite(fan, HIGH);
digitalWrite(fan, LOW);
v1 = GetNumber();
lcd.setCursor(18,0);
lcd.print(v1);
v2 = GetNumber();
lcd.setCursor(18,1);
lcd.print(v2);
v3 = GetNumber();
lcd.setCursor(18,2);
lcd.print(v3);
int GetNumber()
int num = 0;
char key = kpd.getKey();
while(key != '#')
switch (key)
case NO_KEY:
case '0': case '1': case '2': case '3': case '4':
case '5': case '6': case '7': case '8': case '9':
num = num * 10 + (key - '0');
case '*':
num = 0;
lcd.clear();
key = kpd.getKey();
return num;
