Hi. i am trying to use a range sensor with my arduino uno, but the variable rolls over.
int analogPin = 3; // potentiometer wiper (middle terminal) connected to analog pin 3
// outside leads to ground and +5V
double val = 0; // variable to store the value read
Serial.begin(9600); // setup serial
val = analogRead(analogPin); // read the input pin
Serial.println(val); // debug value
Just using that code, i check the value that the sensor gives me. when removing my hand, it reads from 1-5, meaning that there is nothing, when i get my hand closer it increases up and up till it hits about 600, then it starts to go down to 200 again, as i move my hand closer. how do i prevent this?
That is the way the sensor works, it says so in the data sheet. So there is no way to eliminate this other than using two diffrent types of sensors at the same time but that is messy.
G_M must be psychic to know what the datasheet says when the OP didn't say what the sensor was... 8)
But have a look at this chart for a Sharp sensor. It shows clearly, as G_M says, that the output drops again as you get too close. Yours seems to exhibit the same characteristic.
It just so happens I have been looking at distance sensors for a project for a book I am writing so I knew
The real answer is that you can't use the sensor at this close range.
