hola a todos quiero medir la temperatura con un sensor SHT71 sensirion pero tengo unos codigos y ninguno me ha funcionado siempre me sale temperaturas de -40 y humedades de 2% sin importar que hay y he visto que hay una libreria para estos sensores pero no funciona cuando trato de compilar me da error WConstans.h no se ha encontrado no se que pueda ser eso
int gTempCmd = 0b00000011;
int gHumidCmd = 0b00000101;
int shiftIn(int dataPin, int clockPin, int numBits)
int ret = 0;
int i;
for (i=0; i<numBits; ++i)
digitalWrite(clockPin, HIGH);
delay(10); // I don't know why I need this, but without it I don't get my 8 lsb of temp
ret = ret*2 + digitalRead(dataPin);
digitalWrite(clockPin, LOW);
return(ret);
void sendCommandSHT(int command, int dataPin, int clockPin)
int ack;
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
digitalWrite(dataPin, HIGH);// protocolo para la transmision
digitalWrite(dataPin, LOW);
// The command (3 msb are address and must be 000, and last 5 bits are command)
shiftOut(dataPin, clockPin, MSBFIRST, command);
// Verify we get the coorect ack
pinMode(dataPin, INPUT);
ack = digitalRead(dataPin);
if (ack != LOW)
Serial.println("Ack Error 0");
if (ack != HIGH)
Serial.println("Ack Error 1");
void waitForResultSHT(int dataPin)
int i;
int ack;
for(i= 0; i < 100; ++i)
delay(10);
if (ack == LOW)
if (ack == HIGH)
Serial.println("Ack Error 2");
int getData16SHT(int dataPin, int clockPin)
int val;
// Get the most significant bits
val = shiftIn(dataPin, clockPin, 8);
val *= 256;
// Send the required ack
// Get the lest significant bits
val |= shiftIn(dataPin, clockPin, 8);
return val;
void skipCrcSHT(int dataPin, int clockPin)
// Skip acknowledge to end trans (no CRC)
Serial.begin(9600); // open serial
int theDataPin = 10;
int theClockPin = 11;
int ack;
int val;
int temperatura;
int humedad;
sendCommandSHT(gTempCmd, theDataPin, theClockPin);
waitForResultSHT(theDataPin);
val = getData16SHT(theDataPin, theClockPin);
skipCrcSHT(theDataPin, theClockPin);
Serial.print("Temperatura:");
//Serial.print(val, HEX);
temperatura = -40.1 + 0.01 * (float)val;
Serial.print(" ");
Serial.println(temperatura, DEC);
//lee el pin Data, con el comando de humedad y imprime el resultado
sendCommandSHT(gHumidCmd, theDataPin, theClockPin);
Serial.print("umidade:");
humedad = -2.0468 + 0.0367 * val + -0.0000015955 * val * val;
Serial.print(" ");
Serial.println(humedad, DEC);
delay(1000); //demora 1s antes de leer otra vez la temperatura y humedad
