SHT1X.h
* SHT1x Library
* Copyright 2009 Jonathan Oxer <jon@oxer.com.au> / <www.practicalarduino.com>
* Based on previous work by:
* Maurice Ribble: <www.glacialwanderer.com/hobbyrobotics/?p=5>
* Wayne ?: <ragingreality.blogspot.com/2008/01/ardunio-and-sht15.html>
* Manages communication with SHT1x series (SHT10, SHT11, SHT15)
* temperature / humidity sensors from Sensirion (www.sensirion.com).
#ifndef SHT1x_h
#define SHT1x_h
#if (ARDUINO >= 100)
#include <Arduino.h>
#else
#include <WProgram.h>
#endif
class SHT1x
public:
SHT1x(int dataPin, int clockPin);
float readHumidity();
float readTemperatureC();
float readTemperatureF();
private:
int _dataPin;
int _clockPin;
int _numBits;
float readTemperatureRaw();
int shiftIn(int _dataPin, int _clockPin, int _numBits);
void sendCommandSHT(int _command, int _dataPin, int _clockPin);
void waitForResultSHT(int _dataPin);
int getData16SHT(int _dataPin, int _clockPin);
void skipCrcSHT(int _dataPin, int _clockPin);
#endif
SHT1X.cpp
* SHT1x Library
#else
#endif
#include "SHT1x.h"
SHT1x::SHT1x(int dataPin, int clockPin)
_dataPin = dataPin;
_clockPin = clockPin;
/* ================ Public methods ================ */
* Reads the current temperature in degrees Celsius
float SHT1x::readTemperatureC()
int _val; // Raw value returned from sensor
float _temperature; // Temperature derived from raw value
// Conversion coefficients from SHT15 datasheet
const float D1 = -40.0; // for 14 Bit @ 5V
const float D2 = 0.01; // for 14 Bit DEGC
// Fetch raw value
_val = readTemperatureRaw();
// Convert raw value to degrees Celsius
_temperature = (_val * D2) + D1;
return (_temperature);
* Reads the current temperature in degrees Fahrenheit
float SHT1x::readTemperatureF()
const float D2 = 0.018; // for 14 Bit DEGF
// Fetch raw value
// Convert raw value to degrees Fahrenheit
* Reads current temperature-corrected relative humidity
float SHT1x::readHumidity()
int _val; // Raw humidity value returned from sensor
float _linearHumidity; // Humidity with linear correction applied
float _correctedHumidity; // Temperature-corrected humidity
float _temperature; // Raw temperature value
const float C1 = -4.0; // for 12 Bit
const float C2 = 0.0405; // for 12 Bit
const float C3 = -0.0000028; // for 12 Bit
const float T1 = 0.01; // for 14 Bit @ 5V
const float T2 = 0.00008; // for 14 Bit @ 5V
// Command to send to the SHT1x to request humidity
int _gHumidCmd = 0b00000101;
// Fetch the value from the sensor
sendCommandSHT(_gHumidCmd, _dataPin, _clockPin);
waitForResultSHT(_dataPin);
_val = getData16SHT(_dataPin, _clockPin);
skipCrcSHT(_dataPin, _clockPin);
// Apply linear conversion to raw value
_linearHumidity = C1 + C2 * _val + C3 * _val * _val;
// Get current temperature for humidity correction
_temperature = readTemperatureC();
// Correct humidity value for current temperature
_correctedHumidity = (_temperature - 25.0 ) * (T1 + T2 * _val) + _linearHumidity;
return (_correctedHumidity);
/* ================ Private methods ================ */
* Reads the current raw temperature value
float SHT1x::readTemperatureRaw()
int _val;
// Command to send to the SHT1x to request Temperature
int _gTempCmd = 0b00000011;
sendCommandSHT(_gTempCmd, _dataPin, _clockPin);
return (_val);
int SHT1x::shiftIn(int _dataPin, int _clockPin, int _numBits)
int ret = 0;
int i;
for (i=0; i<_numBits; ++i)
digitalWrite(_clockPin, HIGH);
delay(10); // I don't know why I need this, but without it I don't get my 8 lsb of temp
ret = ret*2 + digitalRead(_dataPin);
digitalWrite(_clockPin, LOW);
return(ret);
void SHT1x::sendCommandSHT(int _command, int _dataPin, int _clockPin)
int ack;
// Transmission Start
pinMode(_dataPin, OUTPUT);
pinMode(_clockPin, OUTPUT);
digitalWrite(_dataPin, HIGH);
digitalWrite(_dataPin, LOW);
// The command (3 msb are address and must be 000, and last 5 bits are command)
shiftOut(_dataPin, _clockPin, MSBFIRST, _command);
// Verify we get the correct ack
pinMode(_dataPin, INPUT);
ack = digitalRead(_dataPin);
if (ack != LOW) {
//Serial.println("Ack Error 0");
if (ack != HIGH) {
//Serial.println("Ack Error 1");
void SHT1x::waitForResultSHT(int _dataPin)
int i;
int ack;
for(i= 0; i < 100; ++i)
delay(10);
if (ack == LOW) {
if (ack == HIGH) {
//Serial.println("Ack Error 2"); // Can't do serial stuff here, need another way of reporting errors
int SHT1x::getData16SHT(int _dataPin, int _clockPin)
int val;
// Get the most significant bits
val = shiftIn(_dataPin, _clockPin, 8);
val *= 256;
// Send the required ack
// Get the least significant bits
val |= shiftIn(_dataPin, _clockPin, 8);
return val;
void SHT1x::skipCrcSHT(int _dataPin, int _clockPin)
// Skip acknowledge to end trans (no CRC)
PROGRAM EXAMPLE
* ReadSHT1xValues
* Read temperature and humidity values from an SHT1x-series (SHT10,
* SHT11, SHT15) sensor.
* www.practicalarduino.com
#include <SHT1x.h>
// Specify data and clock connections and instantiate SHT1x object
#define dataPin 10
#define clockPin 11
SHT1x sht1x(dataPin, clockPin);
Serial.begin(38400); // Open serial connection to report values to host
Serial.println("Starting up");
float temp_c;
float temp_f;
float humidity;
// Read values from the sensor
temp_c = sht1x.readTemperatureC();
temp_f = sht1x.readTemperatureF();
humidity = sht1x.readHumidity();
// Print the values to the serial port
Serial.print("Temperature: ");
Serial.print(temp_c, DEC);
Serial.print("C / ");
Serial.print(temp_f, DEC);
Serial.print("F. Humidity: ");
Serial.print(humidity);
Serial.println("%");
delay(2000);
