Sensor to measure up to 10 metres
Hello,
I'm thinking about a project to measure distances of solids with a range of 10 metres. The idea is that my arduino could recive a signal proportional to the distance, and then, arduino would send a signal to my pc with the data.
The problem is that I don't know a "cheap" sensor that measures this ranges. The accuracy is not a problem. A 5% error would be acceptable.
I've seen on the internet some sensors there http://www.vega.com , but are a bit expensive for me.
Has anybody ever used a similar sensor?
Thanks !!
interesting question!
expensive - http://www.dimetix.com/Shop_Dim/home.php?cat=252 -
FYI, (read when searching for the sensors above)
with ultrasound range sensors the signal strength goes down with the 4th power of the distance. ==> doubling the distance gives 16 times less signal back!
