You tried doing a double reading where the first reading is discarded of the A:D?
Show a schematic and a pic of your wiring.
Capacitive moisture sensor? What you are going to find is your program will overwater the plant. Factors to consider is how fast or slow the soil will saturate. When I waited till the soil sensor was at say 40% saturation before turning off the motor 10 minutes later the soil sensor is putting out 80% saturation because the soil moisture takes time to come to homeostasis.
I run the pump for x amount of time, then wait for x amount of time to check how saturated the soil has become. If the soil needs more water then run another x amount of time.
Here is the code I use, you should be able to use it as a model or not:
#include <ESP32Time.h>
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h" // include the connection info for WiFi and MQTT
#include "sdkconfig.h" // used for log printing
#include "esp_system.h"
#include "freertos/FreeRTOS.h" //freeRTOS items to be used
#include "freertos/task.h"
#include <driver/adc.h>
#include <SimpleKalmanFilter.h>
WiFiClient wifiClient; // do the WiFi instantiation thing
PubSubClient MQTTclient( mqtt_server, mqtt_port, wifiClient ); //do the MQTT instantiation thing
ESP32Time rtc;
#define evtDoParticleRead ( 1 << 0 ) // declare an event
#define evtADCreading ( 1 << 3 )
EventGroupHandle_t eg; // variable for the event group handle
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_mqttOK;
QueueHandle_t xQ_RemainingMoistureMQTT;
QueueHandle_t xQ_RM;
QueueHandle_t xQ_Message;
struct stu_message
char payload [150] = {'\0'};
String topic;
} x_message;
int mqttOK = 0;
bool TimeSet = false;
bool manualPumpOn = false;
// interrupt service routine for WiFi events put into IRAM
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
switch (event) {
case SYSTEM_EVENT_STA_CONNECTED:
case SYSTEM_EVENT_STA_DISCONNECTED:
log_i("Disconnected from WiFi access point");
case SYSTEM_EVENT_AP_STADISCONNECTED:
log_i("WiFi client disconnected");
default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
// clear locations
memset( x_message.payload, '\0', 150 );
x_message.topic = ""; //clear string buffer
x_message.topic = topic;
int i = 0;
for ( i; i < length; i++)
x_message.payload[i] = ((char)payload[i]);
x_message.payload[i] = '\0';
xQueueOverwrite( xQ_Message, (void *) &x_message );// send data
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
x_message.topic.reserve(150);
xQ_Message = xQueueCreate( 1, sizeof(stu_message) );
xQ_RemainingMoistureMQTT = xQueueCreate( 1, sizeof(float) ); // sends a queue copy
xQ_RM = xQueueCreate( 1, sizeof(float) );
eg = xEventGroupCreate(); // get an event group handle
sema_mqttOK = xSemaphoreCreateBinary();
xSemaphoreGive( sema_mqttOK );
gpio_config_t io_cfg = {}; // initialize the gpio configuration structure
io_cfg.mode = GPIO_MODE_INPUT; // set gpio mode. GPIO_NUM_0 input from water level sensor
io_cfg.pull_down_en = GPIO_PULLDOWN_ENABLE; // enable pull down
io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_0) ); //bit mask of the pins to set, assign gpio number to be configured
gpio_config(&io_cfg); // configure the gpio based upon the parameters as set in the configuration structure
io_cfg = {}; //set configuration structure back to default values
io_cfg.mode = GPIO_MODE_OUTPUT;
io_cfg.pin_bit_mask = ( 1ULL << GPIO_NUM_4 | (1ULL << GPIO_NUM_5) ); //bit mask of the pins to set, assign gpio number to be configured
gpio_set_level( GPIO_NUM_4, LOW); // deenergize relay module
gpio_set_level( GPIO_NUM_5, LOW); // deenergize valve
// set up A:D channels https://dl.espressif.com/doc/esp-idf/latest/api-reference/peripherals/adc.html
adc1_config_width(ADC_WIDTH_12Bit);
adc1_config_channel_atten(ADC1_CHANNEL_3, ADC_ATTEN_DB_11);// using GPIO 39
xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 10000, NULL, 6, NULL, 1 );
xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 10000, NULL, 5, NULL, 1 ); // assign all to core 1, WiFi in use.
xTaskCreatePinnedToCore( fPublish, "fPublish", 9000, NULL, 3, NULL, 1 );
xTaskCreatePinnedToCore( fReadAD, "fReadAD", 9000, NULL, 3, NULL, 1 );
xTaskCreatePinnedToCore( fDoMoistureDetector, "fDoMoistureDetector", 70000, NULL, 4, NULL, 1 );
xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 3000, NULL, 2, NULL, 1 );
} //void setup()
void fReadAD( void * parameter )
float ADbits = 4096.0f;
float uPvolts = 3.3f;
float adcValue_b = 0.0f; //plant in yellow pot
uint64_t TimePastKalman = esp_timer_get_time(); // used by the Kalman filter UpdateProcessNoise, time since last kalman calculation
float WetValue = 1.07f; // value found by putting sensor in water
float DryValue = 2.732f; // value of probe when held in air
float Range = DryValue - WetValue;
float RemainingMoisture = 100.0f;
SimpleKalmanFilter KF_ADC_b( 1.0f, 1.0f, .01f );
for (;;)
xEventGroupWaitBits (eg, evtADCreading, pdTRUE, pdTRUE, portMAX_DELAY ); //
adcValue_b = float( adc1_get_raw(ADC1_CHANNEL_3) ); //take a raw ADC reading
adcValue_b = ( adcValue_b * uPvolts ) / ADbits; //calculate voltage
KF_ADC_b.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f ); //get time, in microsecods, since last readings
adcValue_b = KF_ADC_b.updateEstimate( adcValue_b ); // apply simple Kalman filter
TimePastKalman = esp_timer_get_time(); // time of update complete
RemainingMoisture = 100.0f * (1 - ((adcValue_b - WetValue) / (DryValue - WetValue))); //remaining moisture = 1-(xTarget - xMin) / (xMax - xMin) as a percentage of the sensor wet dry volatges
xQueueOverwrite( xQ_RM, (void *) &RemainingMoisture );
//log_i( "adcValue_b = %f remaining moisture %f%", adcValue_b, RemainingMoisture );
vTaskDelete( NULL );
void fPublish( void * parameter )
for (;;)
if ( xQueueReceive(xQ_RemainingMoistureMQTT, &RemainingMoisture, portMAX_DELAY) == pdTRUE )
xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
MQTTclient.publish( topicRemainingMoisture_0, String(RemainingMoisture).c_str() );
xSemaphoreGive( sema_MQTT_KeepAlive );
} // for (;;)
} //void fPublish( void * parameter )
void WaterPump0_off()
gpio_set_level( GPIO_NUM_4, LOW); //denergize relay module
vTaskDelay( 1 );
gpio_set_level( GPIO_NUM_5, LOW); //denergize/close valve
void WaterPump0_on()
gpio_set_level( GPIO_NUM_5, HIGH); //energize/open valve
vTaskDelay( 1 );
gpio_set_level( GPIO_NUM_4, HIGH); //energize relay module
void fmqttWatchDog( void * paramater )
int UpdateImeTrigger = 86400; //seconds in a day
int UpdateTimeInterval = 85000; // get another reading when = UpdateTimeTrigger
int maxNonMQTTresponse = 12;
TickType_t xLastWakeTime = xTaskGetTickCount();
const TickType_t xFrequency = 5000; //delay for mS
for (;;)
vTaskDelayUntil( &xLastWakeTime, xFrequency );
xSemaphoreTake( sema_mqttOK, portMAX_DELAY ); // update mqttOK
mqttOK++;
if ( mqttOK >= maxNonMQTTresponse )
ESP.restart();
UpdateTimeInterval++; // trigger new time get
if ( UpdateTimeInterval >= UpdateImeTrigger )
TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
UpdateTimeInterval = 0;
} //void fmqttWatchDog( void * paramater )
void fDoMoistureDetector( void * parameter )
//wait for a mqtt connection
while ( !MQTTclient.connected() )
vTaskDelay( 250 );
int TimeToPublish = 5000000; //5000000uS
int TimeForADreading = 100 * 1000; // 100mS
uint64_t TimePastPublish = esp_timer_get_time(); // used by publish
uint64_t TimeADreading = esp_timer_get_time();
const TickType_t xFrequency = 10; //delay for 10mS
float RemainingMoisture = 100.0f; //prevents pump turn on during start up
bool pumpOn = false;
uint64_t PumpOnTime = esp_timer_get_time();
int PumpRunTime = 11000000;
uint64_t PumpOffWait = esp_timer_get_time();
uint64_t PumpOffWaitFor = 60000000; //one minute
float lowMoisture = 23.0f;
float highMoisture = 40.0f;
for (;;)
//read AD values every 100mS.
if ( (esp_timer_get_time() - TimeADreading) >= TimeForADreading )
xEventGroupSetBits( eg, evtADCreading );
xQueueReceive(xQ_RM, &RemainingMoisture, 0 ); //receive queue stuff no waiting
//read gpio 0 is water level good. Yes: OK to run pump : no pump off. remaining moisture good, denergize water pump otherwise energize water pump.
if ( RemainingMoisture >= highMoisture )
WaterPump0_off();
if ( !pumpOn )
log_i( "not pump on ");
if ( gpio_get_level( GPIO_NUM_0 ) )
if ( RemainingMoisture <= lowMoisture )
//has one minute passed since last pump energize, if so then allow motor to run
if ( (esp_timer_get_time() - PumpOffWait) >= PumpOffWaitFor )
WaterPump0_on();
log_i( "pump on " );
pumpOn = !pumpOn;
//xSemaphoreGive( sema_RemainingMoisture );
log_i( "water level bad " );
WaterPump0_off();
pump goes on runs for X seconds then turn off, then wait PumpOffWaitTime before being allowed to energize again
if ( (esp_timer_get_time() - PumpOnTime) >= PumpRunTime )
log_i( "pump off " );
WaterPump0_off(); // after 5 seconds turn pump off
pumpOn = !pumpOn;
// publish to MQTT every 5000000uS
if ( (esp_timer_get_time() - TimePastPublish) >= TimeToPublish )
xQueueOverwrite( xQ_RemainingMoistureMQTT, (void *) &RemainingMoisture );// data for mqtt publish
TimePastPublish = esp_timer_get_time(); // get next publish time
}// end fDoMoistureDetector()
void MQTTkeepalive( void *pvParameters )
sema_MQTT_KeepAlive = xSemaphoreCreateBinary();
xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
const TickType_t xFrequency = 250; // 250mS
for (;;)
//check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
MQTTclient.loop();
else {
log_i( "MQTT keep alive found MQTT status %s WiFi status %s", String(wifiClient.connected()), String(WiFi.status()) );
if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
connectToWiFi();
connectToMQTT();
vTaskDelete ( NULL );
void connectToMQTT()
// create client ID from mac address
byte mac[5];
int count = 0;
WiFi.macAddress(mac); // get mac address
String clientID = String(mac[0]) + String(mac[4]);
log_i( "connect to mqtt as client %s", clientID );
MQTTclient.disconnect();
MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
vTaskDelay( 250 );
count++;
if ( count == 5 )
ESP.restart();
MQTTclient.setCallback( mqttCallback );
MQTTclient.subscribe( topicOK );
void connectToWiFi()
int TryCount = 0;
while ( WiFi.status() != WL_CONNECTED )
TryCount++;
WiFi.disconnect();
WiFi.begin( SSID, PASSWORD );
vTaskDelay( 4000 );
if ( TryCount == 10 )
ESP.restart();
WiFi.onEvent( WiFiEvent );
} // void connectToWiFi()
void fparseMQTT( void *pvParameters )
struct stu_message px_message;
for (;;)
if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
if ( px_message.topic == topicOK )
mqttOK = 0; // clear mqtt ok count
if ( !TimeSet )
String temp = "";
temp = px_message.payload[0];
temp += px_message.payload[1];
temp += px_message.payload[2];
temp += px_message.payload[3];
int year = temp.toInt();
temp = "";
temp = px_message.payload[5];
temp += px_message.payload[6];
int month = temp.toInt();
temp = "";
temp = px_message.payload[8];
temp += px_message.payload[9];
int day = temp.toInt();
temp = "";
temp = px_message.payload[11];
temp += px_message.payload[12];
int hour = temp.toInt();
temp = "";
temp = px_message.payload[14];
temp += px_message.payload[15];
int min = temp.toInt();
rtc.setTime( 0, min, hour, day, month, year );
log_i( "%s ", rtc.getTime() );
TimeSet = true;
// manual pump control
if ( str_eTopic == topicPumpState )
if ( String(strPayload) == "off" )
WaterPump0_off();
if ( String(strPayload) == "on" )
WaterPump0_on();
manualPumpOn = true;
} //for(;;)
} // void fparseMQTT( void *pvParameters )
void loop() {}
The action is in the void fDoMoistureDetector( void * parameter ) task.
