I have a lot of hollow plastic "bricks", which is for kids to jump between.
I'm looking for teh best choice of sensor for registering if a child has jump to brick/ standing on it.
Jumping "on" and "standing on" are really different; you can detect the shaking/impact. Just standing on something implies measuring the strain/deformation on an object... like a bathroom weight scale.
Impact is straight-forward using an inexpensive knock sensor.
Accelerometers may be feasible if sufficient displayment occurs when step-on.
You could explore RF frequency shift such that a piece of copper foil/circuit board would be the antenna. Basic Theremin concept.
You could explore using stiff spring switch(es) on the bottom of the brick such that the switch is connected when weight is applied... like an inverted foot-switch.
Thanks alot for input, I will surely check it out..
I was also wondering, if its possible to use a photoresistor and glue'ing it to the inside..
Since the plastic is a bit translucent.. But not sure if it would work
It is the word reasonable that is a value judgment. We have members here that due to their location have restrictions on what they can buy and at what price. So to them buying a Arduino Micro would be unreasonable.
As you will probably want to use one sensor per block, and not want a wire to each block then you would be looking for a proper capacitive sensor (not the Arduino library one) and some sort of radio connection, like a BlueTooth module.
I was hoping to put a 'nano' type arduino along with sensor..
And teh having them communicate to a 'master' using Bluetooth or wifi.
so reasonable would be hopefully less the microcontroller itself..
IR is unaffected (unattenuated) by some translucent plastics ... the milky type used on IR outside lighting for example. I believe this to be similar to HDPE... high density polyethelene.
