Sensor wire broken alarm
Hello there !
I am looking for a help or suggestion for a schematic or any other possible idea to
have an alarm sounded, whenever a wire to the sensor NO or NC type (Reed Switch type)
is open. The senor is neither a Analog type nor connected in series. It is a simple ON or OFF type
please share datasheet of your sensor,
its each do program
int Sensor=3;
int alarm=4;
static int Read_status=0;
pinMode(Sensor,INPUT);
 Read_status=digitalRead();
if(Read_status==0)
Serial.println(" alarm is off ");digitalWrite(4,LOW);
}else if (Read_status==1)
Serial.println(" alarm is ON");digitalWrite(4,HIGH);
Well, the "idea" is that you have a resistor in parallel with the sensor.
If the sensor is NC, then if the sensor opens then the current will decrease, but not be cut off entirely as it will if the wire is cut.
Similarly, A NO sensor will draw more current when actuated.
If you wish to detect the wires being bridged (in addition), you have a resistor in series with the sensor.
Thanks
Here is the short description of the sensor
