Sensor with output baud rate of 115200 ,
Hi , I am new to Arduino programming I have a laser sensor with serial output of baudrate or 115200 i want to store its values in an array and later transmit it via I2C but still i am unable to store it in an array help needed its urgent please
you need giver more details
1)datasheet of the laser sensor 2)what you have tried so far 3) expected answers
Hi, Please tell us the make,model and any spec/data sheet that is available please.
Can you please post a copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png or pdf?
Can you please post a copy of your sketch, using code tags? Please use code tags.. See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
Tom..... :)
Also, what Arduino board are you using?
If you have no option but to operate at 115200 baud you will need to use a hardware USART because SoftwareSerial cannot achieve that speed.
...R
