Sensor with two input
Hi All,
I would like to connect two PIR sensors on arduino board. but i have no idea to edit the coding.
int pirSensor = 2;
int ledPin = 7; //relayInput=7
int calibrate = 10;
unsigned long previousTime = 0;
unsigned long int pause = 5000 ;//5second
long unsigned int lowIn;
boolean lockLow = true ;
boolean takeLowTime ;
  pinMode(pirSensor, INPUT);
  pinMode(ledPin, OUTPUT);//relayInput,output
  digitalWrite(pirSensor, LOW);
  digitalWrite(ledPin, LOW);
  Serial.print("calibrating sensor ");
  for (int i = 0; i < calibrate; i++) {
    Serial.print(".");
    delay(100);
  Serial.println(" done");
  Serial.println("SENSOR ACTIVE");
  delay(50);
  if (digitalRead(pirSensor) == HIGH ) {
    digitalWrite(ledPin, HIGH); // (relayInput, LOW)The Relay Input works Inversly
    if (lockLow) {
      lockLow = false;
      Serial.println("---");
      Serial.print("motion detected at ");
      Serial.print(millis() / 1000);
      Serial.println(" sec");
      delay(50);
    takeLowTime = true;
  if (digitalRead(pirSensor) == LOW ) {
    if (takeLowTime) {
      lowIn = millis();          //save the time of the transition from high to LOW
      takeLowTime = false;       //make sure this is only done at the start of a LOW phase
    //if the sensor is low for more than the given pause,
    //we assume that no more motion is going to happen
    if (!lockLow && millis() - lowIn > pause) {
      //makes sure this block of code is only executed again after
      //a new motion sequence has been detected
      lockLow = true;
      Serial.print("motion ended at ");      //output
      Serial.print((millis() - pause) / 1000);
      delay(50);
// The sensor's output pin goes to HIGH if motion is present.
//  However, even if motion is present it goes to LOW from time to time,
//  which might give the impression no motion is present.
// This program deals with this issue by ignoring LOW-phases shorter than a given time,
// assuming continuous motion is present during these phases.
The first step would be to do some searching and learning and get to the point where you understand the code you have and how it works. Once you do that, adding another PIR would be trivial.
