Sensore bmp 280
Buongiorno, premetto che non ho molta esperienza con arduino, io ho un sensore bmp 280 collegato ad arduino uno, il VCC collegato a 3.3v, GND al GND di arduino, SCL al pin A5 ed SDA al pin A4, il codice che uso è questo:
  This is a library for the BMP280 humidity, temperature & pressure sensor
  Designed specifically to work with the Adafruit BMP280 Breakout
  ----> http://www.adafruit.com/products/2651
  These sensors use I2C or SPI to communicate, 2 or 4 pins are required
  to interface.
  Adafruit invests time and resources providing this open source code,
  please support Adafruit andopen-source hardware by purchasing products
  from Adafruit!
  Written by Limor Fried & Kevin Townsend for Adafruit Industries.
  BSD license, all text above must be included in any redistribution
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_BMP280.h>
#define BMP_SCK  (13)
#define BMP_MISO (12)
#define BMP_MOSI (11)
#define BMP_CS   (10)
Adafruit_BMP280 bmp; // I2C
//Adafruit_BMP280 bmp(BMP_CS); // hardware SPI
//Adafruit_BMP280 bmp(BMP_CS, BMP_MOSI, BMP_MISO,  BMP_SCK);
  Serial.println(F("BMP280 test"));
  //if (!bmp.begin(BMP280_ADDRESS_ALT, BMP280_CHIPID)) {
  if (!bmp.begin()) {
    Serial.println(F("Could not find a valid BMP280 sensor, check wiring or "
                     "try a different address!"));
    while (1) delay(10);
  /* Default settings from datasheet. */
  bmp.setSampling(Adafruit_BMP280::MODE_NORMAL,     /* Operating Mode. */
                  Adafruit_BMP280::SAMPLING_X2,     /* Temp. oversampling */
                  Adafruit_BMP280::SAMPLING_X16,    /* Pressure oversampling */
                  Adafruit_BMP280::FILTER_X16,      /* Filtering. */
                  Adafruit_BMP280::STANDBY_MS_500); /* Standby time. */
  Serial.print(F("Temperature = "));
  Serial.print(bmp.readTemperature());
  Serial.println(" *C");
  Serial.print(F("Pressure = "));
  Serial.print(bmp.readPressure());
  Serial.println(" Pa");
  Serial.print(F("Approx altitude = "));
  Serial.print(bmp.readAltitude(1013.25)); /* Adjusted to local forecast! */
  Serial.println(" m");
  delay(2000);
Funziona tutto correttamente, sul monitor seriale viene visualizzata temperatura, pressione altezza, io vorrei fare in modo che per esempio quando la pressione supera un certo livello si accende un led, io non saprei come fare visto che non trovo le variabili, c'è qualcuno più esperto di me che riuscirebbe ad aiutarmi?
Grazie in anticipo
Buonasera e benvenuto :slight_smile: ,
essendo il tuo primo post nella sezione Italiana del forum, nel rispetto del regolamento di detta sezione (… punto 13, primo capoverso), ti chiedo cortesemente di presentarti IN QUESTO THREAD (spiegando bene quali conoscenze hai di elettronica e di programmazione ... possibilmente evitando di scrivere solo una riga di saluto) e di leggere con molta attenzione tutto il su citato REGOLAMENTO
... poi, in conformità al suddetto regolamento, punto 7, cortesemente edita il tuo post qui sopra (quindi NON scrivendo un nuovo post, ma utilizzando il bottone a forma di piccola matita :pencil2: che si trova in basso del tuo post), seleziona la parte di codice e premi l'icona </> nella barra degli strumenti per contrassegnarla come codice.
Inoltre, così com'è non è molto leggibile ... assicurati di averlo correttamente indentato nell'IDE prima di inserirlo (questo lo si fa premendo ctrlT su un PC o cmd T su un Mac, sempre all'interno del IDE). Grazie.
Guglielmo
P.S.: Ti ricordo che, purtroppo, fino a quando non sarà fatta la presentazione nell’apposito thread e sistemato il codice come da regolamento, nessuno ti potrà rispondere, quindi ti consiglio di fare il tutto al più presto. :wink:
Ciao, quello che ti succede è che non salvi le letture in nessuna variabile per poi fare un confronto e accendere o spegnere il led.
per esempio la tua linea:
Dovresti cambiarlo ad esempio in:
Temp = bmp.readPressure();
 Serial.print(Temp);
In questo modo è possibile in seguito effettuare eventuali confronti con la temperatura che è memorizzata nella variabile Temp
Oppure utilizza il seguente modulo:
If (bmp.readPressure() >=...........) { faccio qualunque cosa }
Saluti.
Grazie mille per la risposta, ho provato il primo metodo ma non funziona, invece il secondo funziona benissimo, grazie.
