ho due motor collegati ad arduino (con tanto di motor shield) ma lo sketch non li tocca assolutamente...
si ho modificato lo sketch (o meglio... ho "cercato" di modificare l'esempio in modo corretto) per soli tre pin (a cui sono collegati i tre sensori) facendo ovviamente attenzione che non siano quelli che direzionano/frenano/accelerano i motori..
ma ho paura di averlo modificto malamente, anche perche non conosco molto la libreria
Ecco l'esempio:
#define NUM_SENSORS 8 // number of sensors used
#define TIMEOUT 2500 // waits for 2500 microseconds for sensor outputs to go low
#define EMITTER_PIN 2 // emitter is controlled by digital pin 2
// sensors 0 through 7 are connected to digital pins 3 through 10, respectively
QTRSensorsRC qtrrc((unsigned char[]) {3, 4, 5, 6, 7, 8, 9, 10},
NUM_SENSORS, TIMEOUT, EMITTER_PIN);
unsigned int sensorValues[NUM_SENSORS];
pinMode(13, OUTPUT);
digitalWrite(13, HIGH); // turn on Arduino's LED to indicate we are in calibration mode
for (int i = 0; i < 400; i++) // make the calibration take about 10 seconds
qtrrc.calibrate(); // reads all sensors 10 times at 2500 us per read (i.e. ~25 ms per call)
digitalWrite(13, LOW); // turn off Arduino's LED to indicate we are through with calibration
// print the calibration minimum values measured when emitters were on
for (int i = 0; i < NUM_SENSORS; i++)
Serial.print(qtrrc.calibratedMinimumOn[i]);
Serial.print(' ');
// print the calibration maximum values measured when emitters were on
Serial.print(qtrrc.calibratedMaximumOn[i]);
Serial.print(' ');
// read calibrated sensor values and obtain a measure of the line position from 0 to 5000
// To get raw sensor values, call:
// qtrrc.read(sensorValues); instead of unsigned int position = qtrrc.readLine(sensorValues);
// print the sensor values as numbers from 0 to 1000, where 0 means maximum reflectance and
// 1000 means minimum reflectance, followed by the line position
for (unsigned char i = 0; i < NUM_SENSORS; i++)
Serial.print(sensorValues[i]);
Serial.print('\t');
//Serial.println(); // uncomment this line if you are using raw values
Serial.println(position); // comment this line out if you are using raw values
delay(250);
e come lo ho modificato:
#include <QTRSensors.h>
#define NUM_SENSORS 3 // number of sensors used
QTRSensorsRC qtrrc((unsigned char[]) {4, 5, 6},NUM_SENSORS, TIMEOUT, EMITTER_PIN);
Serial.print(' ');
Serial.print(' ');
Serial.print('\t');
delay(250);
Ho la sensazione che con il mio problema possa centrare quell' "emitter pin" che non so cosa sia
Ma non hai letto bene il commento dell'esempio ???
// This example is designed for use with eight QTR-1RC sensors or the eight sensors of a
// QTR-8RC module. These reflectance sensors should be connected to digital inputs 3 to 10.
// The QTR-8RC's emitter control pin (LEDON) can optionally be connected to digital pin 2,
// or you can leave it disconnected and change the EMITTER_PIN #define below from 2 to
// QTR_NO_EMITTER_PIN.
// The setup phase of this example calibrates the sensor for ten seconds and turns on
// the LED built in to the Arduino on pin 13 while calibration is going on.
// During this phase, you should expose each reflectance sensor to the lightest and
// darkest readings they will encounter.
// For example, if you are making a line follower, you should slide the sensors across the
// line during the calibration phase so that each sensor can get a reading of how dark the
// line is and how light the ground is. Improper calibration will result in poor readings.
// If you want to skip the calibration phase, you can get the raw sensor readings
// (pulse times from 0 to 2500 us) by calling qtrrc.read(sensorValues) instead of
// qtrrc.readLine(sensorValues).
// The main loop of the example reads the calibrated sensor values and uses them to
// estimate the position of a line. You can test this by taping a piece of 3/4" black
// electrical tape to a piece of white paper and sliding the sensor across it. It
// prints the sensor values to the serial monitor as numbers from 0 (maximum reflectance)
// to 1000 (minimum reflectance) followed by the estimated location of the line as a number
// from 0 to 5000. 1000 means the line is directly under sensor 1, 2000 means directly
// under sensor 2, etc. 0 means the line is directly under sensor 0 or was last seen by
// sensor 0 before being lost. 5000 means the line is directly under sensor 5 or was
// last seen by sensor 5 before being lost.
#define EMITTER_PIN QTR_NO_EMITTER_PIN // emitter is controlled by digital pin 2
Serial.print(' ');
Serial.print(' ');
Serial.print('\t');
delay(250);
e la seriale inizia a funzionare, ma restituisce solo valori 0
