I need some help with this little project please guys. I have built a transistor circuit to control the speed of a 3-phase BLDC motor. I want to implement a Back-EMF zero crossing feedback technique to detect the rotor position via an Arduino Nano. The problem is my code is not working on the open loop start up sequence. Can any one give some advice or a code that I could modify to achieve this?
But there is no sensing at all during the open loop startup sequence...
As always there's no point telling us there's a problem with your code and then keeping
the code a secret! Post your code... [correctly please]
Don't they always say that when they're asking for someone to write their code ? ("My code isn't working.....")
Now now guys, no need to make assumptions, I have written code, all I was asking for was some help, I just forgot to post the code. Remember I am a noob to programming and my code might be completely wrong so please be kind.
* Arduino Nano BLDC Controller
* Motor speed is controlled by a single potentiometer
* Motor position is determined with EMF Feedback
This project use open loop startup and bemf zero crossing detection method with ADC.
Speed change can be done only when motor is not running, ADC is used during spinning phase
in zc detection so it can not be used during the motor spinning, but digital speed changing can be implemented.
ZC threshold current should be defined by user depending on the motor type.
* PWM outputs on pins 6(D3), 8(D5), 9(D6), 12(D9), 13(D10) and 14 (D11) at 32 kHz
* Pin 26(A0) is connected to Total Current
* Pin 25(A1) is connected to BEMF Phase 1
* Pin 24(A2) is connected to BEMF Phase 2
* Pin 23(A3) is connected to BEMF Phase 3
* Pin 22(A2) is connected to a potentiometer to change the PWM duty and speed of motor
* Pin 21(D25) is connected to a switch to RUN and STOP Motor
* Pin 20(D24) is connected to a switch to change direction of Motor
// Constants won't change. They're used here to set pin numbers:
const int dirPin = 15;// Direction Switch
const int runPin = 16; // Run Switch
const int potPin = 3; // Potentiometer
const int PWM1H =3; // Phase 1 Low PWM
const int PWM1L =5; // Phase 1 High PWM
const int PWM2H =6; // Phase 2 Low PWM
const int PWM2L =9; // Phase 2 High PWM
const int PWM3H =10; // Phase 3 Low PWM
const int PWM3L =11; // Phase 3 High PWM
const int mEMF1 =6; // Phase 2 High PWM
const int mEMF2 =5; // Phase 3 Low PWM
const int mEMF3 =4; // Phase 3 High PWM
const int mCur =7; // Motor Current
const int rpmConversion = 100; // Pot Value to Actual RPM Conversion factor
//direction definitions
#define motorDirection_CW 0
#define motorDirection_CCW 1
//startup delay, the startup delay for every step is given by startup delay array*LDCSENSORLESS_STARTUPDELAYMULT
// #define BLDCSENSORLESS_STARTUPDELAYS {2000,1900,1800,1600,1400,1200,1000,800,600,550,500,480,460,440,420,400,380,360,355,350,345,340,335,330,325,320,315,310,305,300}
// #define BLDCSENSORLESS_STARTUPCOMMUTATIONS 29 //number of startup commutations
// zc bemf threshold value
#define BLDCSENSORLESS_ZCERRORS 100 //number of zc threshold reading error befor emit a motor startup
#define BLDCSENSORLESS_ZCTHRESHOLD 150
//freq = FCPU/1+(prescaler*ICR1)
//note: ICR1 can not be small, because we have some commands to execute during the interrupt routine
//20000Hz = 8000000Hz/(1+(1*399))
// #define TIMER1_ICR1 199
// #define TIMER1_PRESCALER (1<<CS11) //8 prescaler
// Variables will change:
int currentDirection = motorDirection_CW;
int oldDirection = 0;
int runSwitchState = 0; // Stores state of RUN Switch
int dirSwitchState = 0; // Stores state of Direcion Switch
int BEMF1; //Stores Phase 1 BEMF Voltage Value
int BEMF2; //Stores Phase 2 BEMF Voltage Value
int BEMF3; //Stores Phase 3 BEMF Voltage Value
int mPos; //Stores Motor Position from EMF
int mCurrent; //Stores Motor Total Current
int mSpeed = 0; //Stores speed of the motor in PWM
int mRPM = 0; //Stores speed of the motor in RPM
int mRunning =0; // Stores if motor is running
int potValue = 0; //this variable is used with analog in to measure the position of the potentiometer
int commutationStep; //Stores current step of 6 step cycle
int mDelay; //Stores delay time between Steps
int controlUpdate_interval;
boolean warmUp = true;
pinMode(mEMF1,INPUT);
pinMode(mEMF2,INPUT);
pinMode(mEMF3,INPUT);
pinMode(dirPin,INPUT);
pinMode(runPin,INPUT);
pinMode(potPin,INPUT);
pinMode(mCur,INPUT);
// Outputs for the IR2101 FET Drivers
pinMode(PWM1L,OUTPUT);
pinMode(PWM1H,OUTPUT);
pinMode(PWM2L,OUTPUT);
pinMode(PWM2H,OUTPUT);
pinMode(PWM3L,OUTPUT);
pinMode(PWM3H,OUTPUT);
/* Set PWM frequency on pins 3,5,6,9,10,11 */
// TCCR2B = TCCR2B & 0b11111000 | 1; // PWM ON pins 11 and 3 set to 31kHz
// TCCR1B = TCCR1B & 0b11111000 | 1; // PWM ON pins 9 and 10 set to 31kHz
// TCCR0B = TCCR0B & 0b11111000 | 1; // PWM ON pins 5 and 6 set to 62kHz
// Main Control Loop
void loop(){
// Control Update Loop
controlUpdate_interval++;
if(controlUpdate_interval > 500)
controlUpdate_interval = 0;
controlUpdate();
if (runSwitchState == 1)
// motor_setDirection();
// motor_setSpeed();
motor_warmUp();
// pulseMotor(2300);
// delayMillisecond(2000);
// motor_nextStep();
// motor_runStep(commutationStep);
// motor_Run(currentDirection);
calc_motorSpeed();
motor_off();
void controlUpdate()
// Check for Speed
potValue = analogRead(potPin); //value of the potentiometer
// Check for ON/OFF Switch and Direction
runSwitchState = digitalRead(runPin); // Run State
dirSwitchState = digitalRead(dirPin); // Direction State
// Check Back EMF Position
BEMF1 = analogRead(25)*0.0048828125; //value of EMF for Phase 1
BEMF2 = analogRead(24)*0.0048828125; //value of EMF for Phase 2
BEMF3 = analogRead(23)*0.0048828125; //value of EMF for Phase 3
void motor_setDirection()
// Set currentDirection to Old Direction
oldDirection = currentDirection;
//check for desired direction
if(dirSwitchState == 1)
currentDirection = motorDirection_CCW;
if(currentDirection != oldDirection) //Direction has changed
//stop motor
motor_stop();
//wait for the motor to stop
delay(2000);
void motor_setSpeed()
mSpeed = map(potValue, 0, 0, 1024, 255); //Pot is mapped to desired PWM
void motor_nextStep(void)
commutationStep = 1;
//mSpeed Controls Delay between 100% PWM
//set Delay with Variable PWM
if (currentDirection == motorDirection_CW)
commutationStep++;
else if (currentDirection == motorDirection_CCW)
commutationStep--;
if (commutationStep >= 6)
commutationStep = 0;
if (commutationStep < 0)
commutationStep = 6;
void calc_motorSpeed() // Calculate Motor Speed in RPM
// Send Motor Speed in RPM to Serial Display
mRPM = potValue * rpmConversion;
Serial.print(mRPM);
void motor_stop()
mSpeed = 0;
mDelay = 0;
digitalWrite(PWM1H, LOW);
digitalWrite(PWM1L, LOW);
digitalWrite(PWM2H, LOW);
digitalWrite(PWM2L, LOW);
digitalWrite(PWM3H, LOW);
digitalWrite(PWM3L, LOW);
void motor_off()
if (runSwitchState==0)
mSpeed = 0;
mDelay = 0;
void motor_warmUp()
if (warmUp==true) {
Serial.println("Motor Warmup Started");
for (int i=20; i>0; i--) {
pulseMotor(10000);
pulseMotor(9000);
pulseMotor(8000);
pulseMotor(7500);
pulseMotor(7000);
pulseMotor(6500);
pulseMotor(6000);
pulseMotor(5500);
pulseMotor(5000);
pulseMotor(4500);
pulseMotor(4000);
pulseMotor(3500);
pulseMotor(3100);
pulseMotor(3000);
pulseMotor(2900);
pulseMotor(2800);
for (int i=40; i>0; i--) {
pulseMotor(2750);
pulseMotor(2700);
pulseMotor(2650);
pulseMotor(2600);
pulseMotor(2550);
pulseMotor(2500);
pulseMotor(2450);
pulseMotor(2400);
pulseMotor(2350);
warmUp = false;
while(1)
pulseMotor(2300);
void pulseMotor(int delayMicroSeconds)
if(currentDirection == motorDirection_CW)
Serial.println("Motor Running");
while (1)
digitalWrite(PWM1H, HIGH); //Q1
digitalWrite(PWM2L, HIGH); //Q5
delayMicroseconds(delayMicroSeconds); // wait for a period of time
digitalWrite(PWM3L, HIGH); //G6
digitalWrite(PWM2H, HIGH); //Q2
digitalWrite(PWM3L, HIGH); //Q6
digitalWrite(PWM1L, HIGH); //Q4
digitalWrite(PWM3H, HIGH); //Q3
62kHz PWM? How are you driving your MOSFETs? Hope they are switching a lot
faster than the PWM signal.
Your code is reading the backEMF but this will be slow, analogRead takes 110us, so
0.33ms is used just reading them. I'd recommend over-clocking the ADC to get these
values more rapidly.
You need to add logic to loop looking the the idle phase's back EMF only, waiting for the
zero cross, then using that to commutate. You don't need to read all 3 phases at once.
After the startup-sequence you can jump into the back-EMF sensing code directly.
You seem not to be using PWM at all as all your code uses digitalWrite - that's a recipe
for over-current damage. The start up sequence should be at a lowish PWM value
to limit the current (remember how low the winding resistance is).
There needs to be a secondary PID loop to control PWM - you compare desired speed
(or torque) with actual and use that as the error term.
You should delele this post and send your email address via PM.
Deleting posts deprives other forum users of knowledge and causes confusion, don't do
it, that's something for the moderators to decide.
Does anyone know what happened to open-bldc.org BTW?
Your call to the MAP() function in the motor_SetSpeed() is wrong.
You have ...
You have the parameters in wrong position; also, the max for the pot should be 1023.
The pot has 1024 values, ranged from 0 to 1023
mSpeed = map(potValue, 0, 1023, 0, 255);
Also, for motorStop, if you want braking then you need to set HIGH. Setting them all to LOW will just coast the motor.
Your call to motor_warmUp() won't ever return since at the end it has an endless WHILE(1) loop.
Using names like this that differ only in case like this is likely to cause confusion
for yourself!
The problem with open-loop start up is that you have to limit
the current enough to prevent MOSFETs popping, but not so much that
the motor stalls. This will take some experimentation with PWM drive levels
as this depends on your hardware setup. Having current measuring is extremely
handy.
You need to ramp up the commutation frequency smoothly upto a given point and
then enable the closed-loop commutation feedback. Then you want to look at the
subsequent behaviour to detect if the loop is working (detect loss of lock) and
retry if lock wasn't achieved. You may want to try different acceleration rates after
a retry to cope with different motors and loads.
PS try a PWM freq or 8 to 16kHz in the first instance, you may not need more.
