Sensors 4 project (EN/ESP)
Hello,
I`m a student and I have a project in which I would need sensors to alter the sound produced by an Korg electribe Er1 analog drum machine.
I had thought of using distance sensors to, through the arduino, be able to alter the sound gradually using a midi interface and AbletonLive software.
The thing is if you could guide me in terms of types of sensors (my idea is that it is about 3m approx.) Or if my idea is possible since I do not know much about it.
Thank you very much in advance.
Hola,
Soy estudiante y tengo un proyecto en el necesitaria sensores para alterar el sonido producido por una caja de ritmos analógica Korg electribe Er1 .
Habia pensado en utilizar sensores de distancia para, a través del arduino poder alterar el sonido gradualmente utilizando una interfaz midi y un software estilo AbletonLive.
La cosa es si me podíais guiar en cuanto a tipos de sensores (mi idea es que fuera de unos 3m aprox.) o si es posible mi idea ya que no se mucho sobre el tema.
Muchas gracias de antemano.
A Torque Sensor, Torque Meter or Torque Transducer is a device for torque measurement and recording on a rotating system, like an engine, rotor, cap torque tester, gearbox etc. Datum Electronics is a global leading supplier and manufacturer of static and rotary torque sensor since 1989. We have a wide range of collection for testing and monitoring the application of torque. Datum Electronics offering Shaft Rotating Torque and Rotating Torque Sensor which is used for the measurements of non-contact rotary torque and slip ring. Rotating Torque Measurement appropriate for dynamical measurements of torques.Thank you..
