Hi! I’m working on a project for my robotics class, and I can’t figure out what I’m missing. I’ve watched a lot of videos trying to make it work, but I’ve reached a point where I don’t know what else to do.
The project involves building a car that can move in all directions, controlled by an app on my phone via Bluetooth. The car should also stop automatically when one of its two sensors detects an object too close. However, it should still be able to move in other directions. For example, if the front sensor detects an object at 10 cm, the car shouldn’t move forward but should still be able to move sideways or backward.
The car's base is made with 3D printing, 1 Arduino Uno, 1 expansion board for the Arduino Uno, 1 L298N Motor Drive Controller Board (DC Dual H-Bridge Robot Stepper), 2 DC motors, 2 rear wheels controlled by the motors, 1 "caster" wheel at the front that moves in all directions, 2 HC-SR04 proximity sensors, and 1 HC-05 Bluetooth module. Everything is powered by 6 AA batteries.
Here are the two codes I tested. The car moves fine, and the sensors are sending information, so they’re working. However, when they detect a distance of 10 cm or closer, the car doesn’t stop:
#include <SoftwareSerial.h>
// Bluetooth
SoftwareSerial bluetooth(10, 11); // RX on pin 10, TX on pin 11
// Motor A (left) pins
int IN1 = 2;
int IN2 = 4;
int speedA = 3;
// Motor B (right) pins
int IN3 = 6;
int IN4 = 7;
int speedB = 5;
// Sensor pins
#define TRIG_FRONT 12 // TRIG for the front sensor
#define ECHO_FRONT 13 // ECHO for the front sensor
#define TRIG_BACK 9 // TRIG for the back sensor
#define ECHO_BACK 8 // ECHO for the back sensor
// Speed variables
int leftSpeed = 200; // Base speed for the left wheel
int rightSpeed = 226; // Base speed for the right wheel
float reductionFactor = 0.2;
float diagonalReduction = 0.4; // Reduction factor for diagonals
// Car state
bool carOn = false; // Initial state is off
pinMode(IN1, OUTPUT);
pinMode(IN2, OUTPUT);
pinMode(IN3, OUTPUT);
pinMode(IN4, OUTPUT);
pinMode(speedA, OUTPUT);
pinMode(speedB, OUTPUT);
pinMode(TRIG_FRONT, OUTPUT);
pinMode(ECHO_FRONT, INPUT);
pinMode(TRIG_BACK, OUTPUT);
pinMode(ECHO_BACK, INPUT);
bluetooth.begin(9600);
Serial.println("Bluetooth HC-05 ready. Send 'on' to turn on the car.");
int frontDistance = measureDistance(TRIG_FRONT, ECHO_FRONT);
int backDistance = measureDistance(TRIG_BACK, ECHO_BACK);
// Print results to the serial monitor
Serial.print("Front distance: ");
Serial.print(frontDistance);
Serial.println(" cm");
Serial.print("Back distance: ");
Serial.print(backDistance);
Serial.println("------------------------");
if (bluetooth.available()) {
String command = "";
while (bluetooth.available()) {
char character = bluetooth.read();
command += character;
command.trim();
processCommand(command);
long measureDistance(int trigPin, int echoPin) {
long duration;
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
return duration * 0.034 / 2; // Distance in cm
void processCommand(String command) {
long frontDistance = measureDistance(TRIG_FRONT, ECHO_FRONT);
long backDistance = measureDistance(TRIG_BACK, ECHO_BACK);
if (command == "on") {
carOn = true;
Serial.println("Car turned on.");
} else if (command == "off") {
carOn = false;
stopMotors();
Serial.println("Car turned off.");
} else if (carOn) {
if (command == "f" && frontDistance > 10) moveForward();
else if (command == "a" && backDistance > 10) moveBackward();
else if (command == "e") moveLeft();
else if (command == "d") moveRight();
else if (command == "s") stopMotors();
else if (frontDistance <= 10) stopMotors();
else if (backDistance <= 10) stopMotors();
else Serial.println("Command not recognized.");
Serial.println("Car is off. Send 'on' to turn it on.");
void moveForward() {
digitalWrite(IN1, HIGH);
digitalWrite(IN2, LOW);
digitalWrite(IN3, HIGH);
digitalWrite(IN4, LOW);
analogWrite(speedA, leftSpeed);
analogWrite(speedB, rightSpeed);
void moveBackward() {
digitalWrite(IN1, LOW);
digitalWrite(IN2, HIGH);
digitalWrite(IN3, LOW);
digitalWrite(IN4, HIGH);
void moveLeft() {
void moveRight() {
void stopMotors() {
analogWrite(speedA, 0);
analogWrite(speedB, 0);
// Bluetooth
// Pins for motor A (left)
int IN1 = 2;
int IN2 = 4;
int speedA = 3;
// Pins for motor B (right)
int IN3 = 6;
int IN4 = 7;
int speedB = 5;
// Ultrasonic sensor pins
#define TRIG_FRONT 12 // TRIG pin for the front sensor
#define ECHO_FRONT 13 // ECHO pin for the front sensor
#define TRIG_BACK 9 // TRIG pin for the back sensor
#define ECHO_BACK 8 // ECHO pin for the back sensor
// Speed variables
float reductionFactor2 = 0.4;
// Car state
bool carOn = false;
// Sensor-detected distances
int frontDistance = 0;
int backDistance = 0;
// Distance limit
int distanceLimit = 10; // Minimum distance to stop motors
Serial.println("Bluetooth HC-05 ready. Send 'on' to turn the car on.");
// Check distances before any command
// Display distances in the serial monitor
// Read Bluetooth commands
char c = bluetooth.read();
command += c;
command.trim();
delay(100); // To avoid fast readings
carOn = true;
carOn = false;
stopMotors();
} else if (carOn) {
if (frontDistance < distanceLimit && command == "f") {
Serial.println("Obstacle detected ahead. Movement not allowed.");
} else if (backDistance < distanceLimit && command == "a") {
Serial.println("Obstacle detected behind. Movement not allowed.");
executeCommand(command);
void executeCommand(String command) {
if (command == "f") forward();
else if (command == "a") backward();
else if (command == "e") left();
else if (command == "d") right();
int measureDistance(int trigPin, int echoPin) {
long duration;
void forward() {
void backward() {
void left() {
void right() {
void stopMotors() {
I also noticed that when using more than one proximity sensor, there are libraries available that allow all sensors to work simultaneously. Perhaps I'm missing something related to that.
Any help would be greatly appreciated. Thank you!
