I have a FSR [Force Sensitive Resistor] connected to analog pin 3,
A LM35 temperature sensor connected to analog pin 0,
and a LED connected to digital pin 2,
Objective : I want to use both the sensors and light up the LED whenever the values from the sensors cross a defined value.
I wrote a code for the LM35, using the same setup, I get satisfactory results.
But after writing a code for both the sensors and checking the output, I'm getting 50% of output, i.e., when I press the FSR the LED lights up correctly but when I hold the LM35 to increase the temperature after the set threshold the LED lights up but only partially, its dim.
I'm really confused, please HELP ME!!
Here's the actual code, please let me know what changes have to be made to attain the Objective
const int fsrAnalogPin = A3;
const int LM35 = A0; // analog pin
int fsrReading;
int LM35Reading;
const int LED = 2;
pinMode(LED,OUTPUT);
pinMode(LM35,INPUT);
pinMode(fsrAnalogPin,INPUT);
fsrReading = analogRead(fsrAnalogPin); // Store the readings from the FSR into the variable
LM35Reading = analogRead(LM35);
if(fsrReading > 500) // Set the threshold value
digitalWrite(LED, HIGH); // Activate LED
digitalWrite(LED, LOW); // Deactivate the LEDs
delay(100);
if(LM35Reading >= 60) //value coming from the LM35
digitalWrite(LED,HIGH);
i separated the output of the two LEDs, taking one to the onboard LED on pin13. Just to debug
moved the delay so you can see what's outputting
then added some Serial.print() commands so you can see what your sensors are reporting
I changed the transition values (hysteresis)
untested:
int fsrReading;
int LM35Reading;
const int LED = 2;
const int LED2 = 13;//onboard led
Serial.print("FSR reading: ");
Serial.println(fsrReading);
else if (LM35Reading < 490)//some hysteresis
Serial.print("LM35 reading: ");
Serial.println(LM35Reading);
digitalWrite(LED2,HIGH);
else if (LM35Reading < 55) //some hysteresis
digitalWrite(LED2, LOW);
delay(100);
I suspect it's switching the LED on and off again too soon and so looking like it's only half-on.
BL's idea of using 2x LEDs makes sense: it makes no sense at all to me to use 1x LED when you're checking 2x independent inputs more or less at the same time.
