Sensors? tech needed for basketball analytics (for Major design Project)
For my HSC year 12 MDP I am creating a model of a basketball training facility for teams/players (commercial use) use to use and track data.
I want to be able to track the following information on a court:
-How players interact with the basketball - shooting, dribbling etc.
-Track each players position on the court
-General stats on speed and jump height
-Player to player interaction
Currently The NBA uses services such as:
ShotTracker, , which can provide data on stats and analytics such as scores, number of passes, shot data, distance, player comparison etc. Is anyone aware of what technology or sensors I can use to capture these analytics/stats onto my model practise court. Examples of analytics
-Noah basketball (shots made with tracer)
ShotTracker (live location of players and ball)
ShotTracker (analytics/stats of players)
Currently I am thinking of having the following sensors:
Ultrasonic - for determine player distances
Dual sense camera - track ball players
Tracker for location on the court -wearable gps
Tracker/ sensor on the ball? - possibly gyro
I have done initial research however I am confused on how to get started in bringing this concept to life. I know how to create the physical model, it is the coding/ electronics/ Arduino boards that I needed some guidance with. I have however done discussed this with chatgpt though i dont know how feasible it is.
I know this can be alot so any help or advice would be appreciated.
Discussion with chatgpt:
Question asked was my questions above "For my MDP I am creating a model..."
Chatgpt:
Creating a basketball training facility with sensors to track player interactions and statistics is a fascinating project. To bring this concept to life, you can use a combination of sensors, cameras, and microcontrollers like Arduino. Here's a general guide to help you get started:
1. Sensors and Hardware:
a. Player Position Tracking:
  • Ultrasonic Sensors: These can help you measure distances and track player positions on the court. Mount them around the court to create a grid. As players move, their positions can be calculated based on the sensor readings.
  • Cameras: Use dual-sense cameras to capture the overall court and player movements. Computer vision algorithms can be applied to analyze player positions.
b. Ball Interaction:
  • Accelerometers/Gyroscopes: Attach sensors to the basketball to measure its movement, spin, and acceleration. This will help track dribbling, shooting, and ball handling skills.
  • Pressure Sensors: Placing sensors on the court where the ball is frequently used (e.g., near the hoop or key areas) can help detect ball impact and contact time, providing data on shot accuracy.
c. General Stats:
  • Speed and Jump Height Sensors: Accelerometers can also be used to measure player speed and can be combined with other sensors to estimate jump height during specific activities.
2. Microcontrollers and Communication:
  • Arduino/Raspberry Pi: Use these microcontrollers to interface with your sensors. Arduino, for example, can process sensor data, perform calculations, and communicate with a central system.
  • Wireless Communication: Implement a wireless communication protocol (Bluetooth, Wi-Fi, etc.) to send data from sensors to a central hub for processing and storage.
3. Data Processing and Storage:
  • Central Processing Unit (CPU): Use a computer or a powerful microcontroller to process the incoming data, run analytics, and generate statistics.
  • Database: Store the collected data in a database for historical analysis and trend tracking.
4. Software Development:
  • Coding Languages: Depending on your expertise, use languages like Python, C++, or others to write the software for data processing, analytics, and visualization.
  • User Interface: Develop a user-friendly interface to display real-time data, historical statistics, and player feedback.
5. Integration:
  • APIs: If applicable, integrate APIs from existing sports analytics platforms or devices for additional insights.
  • Machine Learning: Consider implementing machine learning algorithms to enhance predictive analytics and provide personalized feedback.
6. Testing and Calibration:
  • Calibration: Regularly calibrate sensors to ensure accuracy and reliability.
  • Testing: Conduct thorough testing to ensure that the system accurately captures and processes data.
7. Documentation and Support:
  • Documentation: Document your hardware setup, software code, and data processing methods for future reference.
  • User Support: Provide user guides and support for coaches and players using the system.
By combining these elements, you can create a comprehensive basketball training facility that tracks player interactions, statistics, and facilitates data-driven improvements. Start with a prototype to test the feasibility of your setup and gradually refine it based on feedback and performance.
Anonymous
Can you give me an indication on how to get started with creating this court. What sensors should I purchase and give me step by step details of how to put it all together
ChatGPT
ChatGPT
Certainly! Here's a step-by-step guide to get you started with creating the basketball training facility. This guide assumes a basic understanding of electronics, coding, and the ability to work with sensors and microcontrollers.
1. Define Requirements:
  • List the specific metrics you want to measure (player positions, ball movements, speed, etc.).
  • Determine the coverage area of your sensors on the court.
2. Choose Sensors:
    • Purchase multiple ultrasonic sensors (HC-SR04 is a common choice).
    • Space them around the court, creating a grid.
    • Connect them to Arduino for distance measurements.
  • Cameras:
    • Select dual-sense cameras with a wide field of view.
    • Consider using a computer vision library (OpenCV) for player tracking.
    • Purchase small, lightweight accelerometers (MPU-6050 is widely used).
    • Attach them to the basketball to measure ball movements.
  • Pressure Sensors:
    • Choose pressure sensors (Force-sensitive resistors) for impact detection.
    • Place them strategically on the court.
3. Select Microcontrollers:
  • Arduino or Raspberry Pi:
    • Choose a microcontroller based on your processing needs.
    • Arduino is suitable for simpler tasks, while Raspberry Pi offers more processing power.
4. Set Up Microcontrollers:
  • Connect Sensors:
    • Wire the sensors according to their datasheets.
    • Test each sensor individually to ensure proper functionality.
  • Install Necessary Libraries:
    • If using Arduino, install libraries for sensors (e.g., NewPing for ultrasonic sensors, Wire for I2C sensors).
5. Wireless Communication:
  • Choose Communication Protocol:
    • Decide on a wireless communication method (Bluetooth, Wi-Fi, etc.).
    • Implement communication between sensors and microcontroller.
6. Data Processing and Storage:
    • Use a computer or Raspberry Pi for data processing.
    • Install Python and necessary libraries for data analysis.
  • Database:
    • Set up a database (SQLite or MySQL) to store collected data.
7. Software Development:
  • Coding Languages:
    • Write code to read data from sensors.
    • Implement algorithms for player tracking, ball movement analysis, and other desired metrics.
  • User Interface:
    • Create a simple user interface to display real-time and historical data.
8. Integration:
  • APIs and Machine Learning:
    • If needed, integrate third-party APIs or implement machine learning algorithms.
9. Testing and Calibration:
  • Calibration:
    • Calibrate sensors to ensure accuracy.
    • Fine-tune algorithms for optimal performance.
  • Testing:
    • Test the system in controlled environments before deploying on the court.
10. Documentation and Support:
  • Document Setup:
    • Create comprehensive documentation for hardware and software setup.
  • User Support:
    • Provide user guides and support for coaches and players.
11. Prototyping:
  • Build a Prototype:
    • Develop a smaller-scale prototype to test your setup and make improvements.
12. Deployment:
  • Install on Court:
    • Mount sensors in their designated locations on the court.
    • Connect everything according to your setup.
13. Iterate:
  • Gather Feedback:
    • Collect feedback from coaches, players, and users.
    • Iterate on your design based on feedback and performance.
Remember to start with a small-scale prototype and gradually scale up. This step-by-step approach will help you identify and address challenges along the way. Good luck with your basketball training facility project!
That is what forum members recommend, as well. But then, ChatGPT studied all the forum responses to make up its recommendation.
This project is not at all feasible with Arduino. Too slow, too little memory, etc. You need cameras and high power computing to do the image processing and analysis.
So, you’ve now embarked on an AI project from the ground floor.
Where you are now, is holding a lot of generalisations and assumptions - which is fine, but starts you on a complex journey of many, many ChatGPT queries, and possibly thousands of man hours of development.
The time will be spent in the hundreds of generations* of refining your queries and results, and iterations of output to realise your goal.
Remember the G in GPT stands for Generational
It’s a really interesting project, but requires extensive discipline on your part to ensure it’s going where you expect. You’re not going to get a single answer that completes your project.
Fun, but nothing like easy ! and maybe a bit expensive as well as you iterate through the revisions.
This is highly complex , very difficult task .
I would not attempt it …..needs a team of people, with specialisation in the area and a hardware budget in the 5 figure range , probably more .
As there has been no response for a couple of months …
Hi @hiro-nakamura ,
well, sounds like ChatGPT got you all setup, cool..
had a similar request recently, football not basket ball..
quick check for me, shows me they got an app for that..
siq-basketball
smart ball, get one we'll hack it.. :slight_smile:
good luck.. ~q
Show it.
