Sentence "IF" is not working
Hi all !
This is my 1st post in forum, sorry in advance if Im breaking any policy,
Well, the question is related to the next case, I want to write something in the serial monitor only for 1 time, but the program is writting in the monitor again and again… so I declare a boolean variable with “0” in the set up, and when enter to the condition (if x=0) turns to 1; but it´s no working and I haven´t a clue.
Please, I hope that you can help me with this issue…
Here the code and thanks in advance !!!
For this I´m using a potenciometer for this excercise, here the code:
int x;
int stat;
int btn_mode;
  x=0;
  Func_Read();
void Func_Read(){
btn_mode = analogRead(A0);
//FIND THE STATUS DEPENDING ON POTENCIOMETER
if (btn_mode >= 0 && btn_mode < 342); {
stat=1;
if (btn_mode >= 342 && btn_mode < 683); {
stat=2;
if (btn_mode >= 683 && btn_mode < 1024); {
stat=3;
// END OF STATUS FINDING
if ((stat ==1) && (x == 0)); {
    Serial.println("RECIBIR");
    x=1;
delay(300);
if (btn_mode >= 0 && btn_mode < 342); <———<<<< get rid of the ;
A common mistake, made three times here.
larryd:
Larryd,
Hope you´re well,
I changed and simplified the code, but the problem remains. It doesn´t matter the position of the potenciometer, always is printing the message “Hello” each 0.3 seg.
int x;
int btn_mode;
x=0;
if (x == 0); {
Serial.println(“Hello”); //Should show the message only 1 time, but is printing in serial monitor many times
x=1;
//CONDITION2
//CONDITION3
delay(300);
As others have pointed out,
Remove the four semicolons that are behind the closing bracket of the condition.
if(xxx);{
if(xxx) {
Leo…
Wawa:
if(xxx);{
if(xxx) {
Leo..
Clear, thank you very much... to you and Larryd
