Separate Interrupts For High/Low Pin Status
Is it possible to have separate hardware interrupts for pin high and low status run concurrently:
attachInterrupt(0,InterruptA_High,RISING);
attachInterrupt(0,InterruptA_Low,FALLING);
attachInterrupt(1,InterruptB_High,RISING);
attachInterrupt(1,Interruptb_Low,FALLING);
I'm guessing not, but this would allow me to reduce that amount of code inside the interrupts for a high frequency application.
attachInterrupt(0,InterruptA_Low,TRAILING);
will definitely not work because TRAILING is not a valid parameter, but have you tried attaching 2 interrupts to the same pin with the correct parameter ?
http://arduino.cc/en/Reference/AttachInterrupt
You read my post before I corrected the code to say "FALLING." Anyway, I tried it and it doesn't seem to fire both, just on the last call to attachInterrupt().
The options are exclusive. Try CHANGE
you should use CHANGE and in the ISR you can go to the right code depending on the line. Fastest is to keep the state yourself.
void myISR()
  state = 1 - state;
  if (state == 1) myHIGHISR();
  else myLOWISR();
works like a charm (note that digitalRead(pin) takes more time)
renniejohnson:
You read my post before I corrected the code to say “FALLING.” Anyway, I tried it and it doesn’t seem to fire both, just on the last call to attachInterrupt().
The last call overrides any previous calls.
You can have one and one only ISR per interrupt (external or internal).
Mark
Thanks guys. I've got both interrupts working on a quadrature encoder and I'm only getting accuracy up to about 50KHz. Is there a faster way to read the pin status than "digitalRead()"?
bitRead(PINX,n) is simple to use, and will get you most of the available speed increase.
Direct Port Manipulation where you read both pins at once is slightly faster.
  pinMode(2,INPUT_PULLUP);
  pinMode(3,INPUT_PULLUP);
  unsigned long microsStart=micros();
  for (int i=0;i<1000;i++){
    digitalRead(2);
    digitalRead(3);
  unsigned long microsEnd=micros();
  Serial.println(microsEnd-microsStart);
    bitRead(PIND,2);
    bitRead(PIND,3);
  microsEnd=micros();
    (PIND & B00001100)>>2;
  microsEnd=micros();
Output
8740
596
528
With this sketch I can count up to about 200 kHz.
volatile bool counting;
volatile unsigned long events;
unsigned long startTime;
const unsigned long INTERVAL = 1000;  // 1 second
void activateInterrupt0 ()
  EICRA &= ~(bit(ISC00) | bit (ISC01));  // clear existing flags
  EICRA |=  bit (ISC01);    // set wanted flags (falling level interrupt)
  EIFR   =  bit (INTF0);    // clear flag for interrupt 0
  EIMSK |=  bit (INT0);     // enable it
  }  // end of activateInterrupt0
void deactivateInterrupt0 ()
  EIMSK &= ~bit (INT0);     // disable it
  }  // end of deactivateInterrupt0
ISR (INT0_vect)
  if (counting)
    events++;
  }  // end of ISR (INT0_vect)
void setup ()
  Serial.begin (115200);
  Serial.println ();
  activateInterrupt0 ();
  }  // end of setup
void showResults ()
  Serial.print ("I counted ");
  Serial.println (events);
  }  // end of showResults
void loop ()
  if (counting)
    // is time up?
    if (millis () - startTime < INTERVAL)
      return;
    counting = false;
    showResults ();
    }  // end of if
  noInterrupts ();
  events = 0;
  startTime = millis ();
  counting = true;
  interrupts ();
  }  // end of loop
Remember though that this is counting every 5 µS. An interrupt routine takes about that time to enter and leave. So you won’t get much faster than that with interrupts.
cattledog’s suggestion of using PIND in a tight loop is about as good as you can get, and that assumes you don’t want to do anything else. His figures suggest about one read per µS which sounds about right.
To get even higher frequency counts, use the hardware timers/counters. See:
Timers
My example there counted up to 5 MHz. After all, it’s the job of the hardware counter to count, may as well use it.
