OP's code, properly posted below.
// This file is part of RTIMULib-Arduino
// Copyright (c) 2014-2015, richards-tech
// Permission is hereby granted, free of charge, to any person obtaining a copy of
// this software and associated documentation files (the "Software"), to deal in
// the Software without restriction, including without limitation the rights to use,
// copy, modify, merge, publish, distribute, sublicense, and/or sell copies of the
// Software, and to permit persons to whom the Software is furnished to do so,
// subject to the following conditions:
// The above copyright notice and this permission notice shall be included in all
// copies or substantial portions of the Software.
// THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
// INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
// PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
// HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION
// OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE
// SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
#include <Wire.h>
#include "I2Cdev.h"
#include "RTIMUSettings.h"
#include "RTIMU.h"
#include "RTFusionRTQF.h"
#include "CalLib.h"
#include <EEPROM.h>
RTIMU *imu; // the IMU object
RTFusionRTQF fusion; // the fusion object
RTIMUSettings settings; // the settings object
// DISPLAY_INTERVAL sets the rate at which results are displayed
#define DISPLAY_INTERVAL 300 // interval between pose displays
// SERIAL_PORT_SPEED defines the speed to use for the debug serial port
#define SERIAL_PORT_SPEED 115200
unsigned long lastDisplay;
unsigned long lastRate;
int sampleCount;
int errcode;
Serial.begin(SERIAL_PORT_SPEED);
Wire.begin();
imu = RTIMU::createIMU(&settings); // create the imu object
Serial.print("ArduinoIMU starting using device "); Serial.println(imu->IMUName());
if ((errcode = imu->IMUInit()) < 0) {
Serial.print("Failed to init IMU: "); Serial.println(errcode);
if (imu->getCalibrationValid())
Serial.println("Using compass calibration");
Serial.println("No valid compass calibration data");
lastDisplay = lastRate = millis();
sampleCount = 0;
// Slerp power controls the fusion and can be between 0 and 1
// 0 means that only gyros are used, 1 means that only accels/compass are used
// In-between gives the fusion mix.
fusion.setSlerpPower(0.02);
// use of sensors in the fusion algorithm can be controlled here
// change any of these to false to disable that sensor
fusion.setGyroEnable(true);
fusion.setAccelEnable(true);
fusion.setCompassEnable(true);
unsigned long now = millis();
unsigned long delta;
int loopCount = 1;
while (imu->IMURead()) { // get the latest data if ready yet
// this flushes remaining data in case we are falling behind
if (++loopCount >= 10)
continue;
fusion.newIMUData(imu->getGyro(), imu->getAccel(), imu->getCompass(), imu->getTimestamp());
sampleCount++;
if ((delta = now - lastRate) >= 100) {
//Serial.print("Sample rate: "); Serial.print(sampleCount);
if (imu->IMUGyroBiasValid())
//Serial.println(", gyro bias valid");
//else
//Serial.println(", calculating gyro bias");
sampleCount = 0;
lastRate = now;
if ((now - lastDisplay) >= DISPLAY_INTERVAL) {
lastDisplay = now;
// RTMath::display("Gyro:", (RTVector3&)imu->getGyro()); // gyro data
// RTMath::display("Accel:", (RTVector3&)imu->getAccel()); // accel data
// RTMath::display("Mag:", (RTVector3&)imu->getCompass()); // compass data
RTMath::displayRollPitchYaw("GyroPos:", (RTVector3&)fusion.getFusionPose()); // fused output
RTMath::displayRollPitchYaw("GyroPos:", (RTVector3&)fusion.getFusionPose()); // Copied from two line 110
Serial.print(vec.x() * RTMATH_RAD_TO_DEGREE);
// Reading RTFuisionRTQF portion
// RTFusionRTQF::RTFusionRTQF(RTVector3&)fusion.Gyro(x);
// Serial.print(m_measuredQPose.setX(-m_measuredQPose.x());
Nowhere in your Arduino program do you declare the variable "vec" or put anything in it to print.
Change your added Serial.print() statement to
RTVector3 vec = fusion.getFusionPose();
Note that these are not the "Gyro values", FusionPose is the estimated absolute orientation of the sensor.
