Separating int values
I have a question about translating an int value (say 15) into two separate values (1 and 5). This might be called something, but I am too new to know what to search for. The reason for this is to pass these values to two 74HC595 shift registers in order to display a score on a dual 7-segment display (so that I can display greater than 9). I have all the wiring set up, and the code for the game, I just need to know how to split the numbers and store them. Thanks in advance.
Something like this should do it
int val=15;
char tens = val / 10 + '0';
char units = val - (tens * 10) + '0';
Andrew
Much thanks.
While I am storing the new values as ints in order to pass to the shift register functions, it worked anyways. I had actually thought about dividing by 10 for the tens value, but I didn't realize the decimal (1.5) would be parsed. Much appreciated though.
I'm not sure what you mean there, but when dealing with integer variables, any fractional part is discarded after a division operation. This is sometimes called "truncating division".
int val=15;
char tens = val / 10 + '0'; char units = val - (tens * 10) + '0';
tens is good, but you can have the units "faster" with:
char units = (val % 10) + '0';
(well, you'll save a few bytes on your board...)
tens is good, but you can have the units "faster" with...
I was feeling too lazy to explain the modulo function, and doing it the long way makes it more obvious what you're doing.
Andrew
Thanks for all the replies/discussions. I got the setup working perfectly following this advice. Fruits of your help:
